Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Northern California
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Northern California Northern California
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-06-2008, 11:12 PM   #1
qwik02
CF Senior Member
qwik02's Avatar
Default Question about TPS
Hi Guys,
I know this is a tech question...but, I would really like to hear from members locally.
I took my car to the dealership just down the street from my workplace and asked them to replace a tire pressure sensor. I was getting the xxx for my right front sensor. I assumed the battery in the sensor had died and asked them to put a new sensor in. I also asked that they reprogram the rear sensors because when my tires were installed the rims were swapped thus my right and left rears were reading opposite of where the tires were located.
Today, I am driving my car and my DIC gives me the error for the tire sensors. I check which sensor is not reading correctly and find out all four sensors are now showing xxx. It was too late to take it to the dealership today. Any thoughts as to what would cause this? I'd like to hear from some of you before I take it to the dealership in the morning.
Thanks,
Mike
qwik02 is offline   Reply With Quote
Old 03-07-2008, 02:38 AM   #2
SpankUU
CF Senior Member
SpankUU's Avatar
Mike,
I would get all 4 of them re-programmed. You can have this done any where that has the TPS tool. Discount Tires, Big O, they all have them and normally do not charge to reset them. If you take a ride out to Fairfield RichieRichZ06 at Woodard Chevy I'm sure will help you out.
The reset procedure calls for all 4 to be reset one not one or two. You have to start with the front driver side, then front pass, rear pass and rear driver side. Once in the learning mode the horn will toot at each one and a double toot on the last one. It takes about 1 min to do all four.
SpankUU is offline   Reply With Quote
Reload this Page Question about TPS
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Question about Burn off box BrettWithVette C4 Tech/Performance 11 04-26-2004 04:50 PM
Question about How You Drive Effecting PCM vette6799 C5 Z06 Discussion 32 10-25-2002 06:16 PM
Question about CALPAK and LIMP HOME mode > 85Procharged383 C4 Scan & Tune 12 09-20-2002 06:57 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
