Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Northern California
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Northern California Northern California
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-03-2008, 06:22 PM   #1
ChargedC6
CF Senior Member
ChargedC6's Avatar
Default any tips for installing lowering bolts..?
I just got started installing the rear lowering bolts any tips to make it easy. i did a search didnt really find anything usefull. thanks
ChargedC6 is offline   Reply With Quote
Old 03-03-2008, 06:31 PM   #2
rastarajah
CF Senior Member
rastarajah's Avatar
Send a message via AIM to rastarajah
Jack it up, take off the wheel, unbolt the sway bar, unbolt the shock from the top, unbolt the LCA from the ball join on the spindle.
pop it down, use another jack, put it on the spindle and jack it up. Higher it as you please to give you enough clearance to get the bolt out/in.
That's how I did mine. The rear is more difficult than the front, good luck.
__________________
1993 LS1 RX7 - 1996 Civic EX - 2005 C6 Z51 Corvette
rastarajah is offline   Reply With Quote
Old 03-03-2008, 07:37 PM   #3
jcb5565
CF Senior Member
jcb5565's Avatar
Don't forget to use jack stands.
jcb5565 is offline   Reply With Quote
Old 03-03-2008, 08:16 PM   #4
codename Bil Doe
CF Senior Member
codename Bil Doe's Avatar
Send a message via AIM to codename Bil Doe
Do like rasta says and shouldn't take you more than 1.5hr. Mark your camber bolts and don't worry about popping the LCA's cuz you're going to have to get an alignment anyways.
codename Bil Doe is offline   Reply With Quote
Old 03-03-2008, 09:00 PM   #5
ChargedC6
CF Senior Member
ChargedC6's Avatar
well that was a hell of alot easier then i thought it was gonna be just went and drove around for 30 minutes or so and looks like it settled down pretty good. i left the new bolts about with about a 1/4 of an inch from the leaf spring.
i used 2 jacks and jack stands raised the car, took off the shock, sway bar, and Upper control arm(the bottom was impossible to seperate from the ball joint without ripping the boot), then took a bottle neck jack and put it as far up on the leaf spring as possible raising it untill just before it started to lift the car and the stock bolts came right out very easy. The stock front ones go low enough so im not going to do those it scrapes on everything already.
thanks for the advice guys!
Reload this Page any tips for installing lowering bolts..?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Calling LARS and other Carb experts. . . hudman C3 Tech/Performance 11 12-15-2002 11:29 PM
Q-Jet Problems and Tips lars C3 Tech/Performance 19 11-15-2002 01:05 PM
Poly Suspension bushing install BobMachus C4 Tech/Performance 14 02-13-2002 01:22 PM
Opinions on cold air screens...good idea or good idea for a money making gimmick? Drop_Top_Dave C5 Tech 21 08-13-2001 10:51 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
