Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Northern California
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Northern California Northern California
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-30-2007, 06:00 PM   #1
rtpman2007
Junior Member
Default Cheap Vararam installation?
Hi, I am new here and have a 2007 C6 A6. I am getting the Vararam CAI and the spacer. Does anyone know where I can get them installed cheaply? I know that both Synergy and Newteck do the work but they are both expensive. Hate to spend $180-200 for an installation. Also looking to have the 160 thermo done at the same time. Does the fan setting need to be done by a tuner or can anyone do it?
rtpman2007 is offline   Reply With Quote
Old 05-30-2007, 06:50 PM   #2
TM-Z06
CF Senior Member
Send a message via Yahoo to TM-Z06
Install the vararam yourself - it should not be that difficult. As for the fans, you either need a hand-held tuner, or have Synergy / Newtech do it.
TM-Z06 is offline   Reply With Quote
Old 05-30-2007, 06:58 PM   #3
BlakShark
CF Senior Member
BlakShark's Avatar
Send a message via AIM to BlakShark
Quote:
Look at it this way. 200.00 will get you the work done in a professional Manner. Just my Input.
BlakShark is offline   Reply With Quote
Old 05-30-2007, 07:12 PM   #4
SNAKEKILLER!
CF Senior Member
SNAKEKILLER!'s Avatar
Veraram.....easy install...30 minutes max...
Thermo......dont bother unless you're going to have you're fans switched by handheld or tuner...Otherwise you will not notice a difference
SNAKEKILLER! is offline   Reply With Quote
Old 05-30-2007, 10:49 PM   #5
csun213
CF Senior Member
csun213's Avatar
Anyone willing to install my Vararam? I am not handy with tools and don't want to hurt my C6.
csun213 is offline   Reply With Quote
Old 06-05-2007, 01:35 AM   #6
Mrs Cali Z06
CF Senior Member
Mrs Cali Z06's Avatar
Send a message via Yahoo to Mrs Cali Z06
Very easy install and you can have it tuned or about the third time you run it the computer does learn to compensate. Good luck!
Mrs Cali Z06 is offline   Reply With Quote
Old 06-05-2007, 12:39 PM   #7
0Synergy Motorsports
CF Senior Member
Synergy Motorsports's Avatar
Send a message via AIM to Synergy Motorsports
The C5 install and the C6 install are way different. I would say the C5 is easier. The C6 you have to pull apart a few more things, cut a big portion of the shroud off, and put it all back together again. You can do it if you have some patients, its not too bad.
rick
Synergy Motorsports is offline   Reply With Quote
Reload this Page Cheap Vararam installation?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
About to toss down 500 or so for first mod - what do you suggest? 5.0_CJ C5 Tech 13 03-22-2005 03:58 AM
Vortex Vs. Vararam... any real gains? Cobra4B C5 Tech 24 12-26-2004 04:55 PM
Is there a reason to buy an aftermarket intake instead of the zip tie mod? Zippy The Wonderdog C5 General 28 10-15-2004 08:19 PM
Kooks 1 7/8 headers dyno numbers rplaster C5 Tech 55 03-30-2004 11:08 AM
Anyone tried the Halltech Tunnel Ram Air Pak?????? 98vettecpe C5 Tech 28 08-10-2003 06:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
