05-28-2007, 11:12 PM
CF Senior Member
I will be there. This time I can at least beat Vic's Trailer.
05-29-2007, 11:37 AM
CF Senior Member
You guys coming up 580??? Passing through Tracy?
__________________
2001 Millennium Yellow Corvette Z06 LOVE IT
ALL STOCK 500ishHP
2000 Millennium Yellow Corvette TOTALLED POS
NOT STOCK
420.15hp & 459.37tq
05-29-2007, 11:46 AM
CF Senior Member
05-29-2007, 12:52 PM
CF Senior Member
Quote:
Originally Posted by
teddyca
I think they'll take 80 past Davis then to SacRaceway. I might be wrong. I'm gonna take 12 to Lodi at Hgy 5, then towards Sac and the raceway.
05-29-2007, 01:48 PM
CF Senior Member
teddyca
We will be going on 80 all the way up
05-29-2007, 01:50 PM
CF Senior Member
Looks like I will just see you all there.
05-30-2007, 01:55 AM
CF Senior Member
i wanna roll wit yall....you guys will be going through hercules. any pit stops by here?
05-30-2007, 01:57 AM
CF Senior Member
are you guys going to the carshow?
05-30-2007, 02:00 AM
CF Senior Member
lowrod vette
im going to the sunday drags.
05-30-2007, 02:02 AM
CF Senior Member
SKISKIRT
Your vette is off the hook! Are you rolling on 20`s
05-30-2007, 02:14 AM
CF Senior Member
lowrod vette
thx bro.no way! stock slammed 2.5 in.
05-30-2007, 02:16 AM
CF Senior Member
SKISKIRT
Nice! Yeh I wanted mine on the floor so I had to put hydralics two pumps 3 batteries
05-30-2007, 02:21 AM
CF Senior Member
lowrod vette
ahh damm! guess im gonna need a pic of your ride. ill be looking for ur car.
05-30-2007, 02:34 AM
CF Senior Member
SKISKIRT
we will be rolling be that way you could alway find us on the freeway pm me yur phone # and i will call you when we get close to your area
05-30-2007, 02:59 AM
CF Senior Member
jhong321
pm sent
05-31-2007, 12:39 AM
CF Senior Member
I can`t make it sunday but I`ll be there saturday maybe you can make it out there.
05-31-2007, 12:40 AM
CF Senior Member
__________________
Yes it has Hydraulics 2 pumps 3 batteries front back & side to side & 20in. rims:
05-31-2007, 12:43 AM
CF Senior Member
We will be trailering the 85 leaving Dublin about 7 or so. You will probably pass us on your way over.......DON'T forget the wave.
__________________
1985 Coup -ZZ4 balanced, LPE 74211 cam, AFR 180 heads, SuperRam base, runners & plenum, cut out air box, K & N filter, power coupler, 52MM TB, March pulleys, AFPR, Accel injectors, Walbro FP, 1.6 RR, chip by TJWONG, 160 stat, cut back plugs, 8.5MM MSD wires, Brute Thunder Coil, custom camber-brace,TRANSGO shift kit, 2400 stall converter, cross drilled rotors, SS brake lines, VBP camber rods, IAS Edelbrock shocks, custom crossover on exhaust, Magnflow cat, 3.07 gears, 13.2 @107.2 MPH in 1/4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
