Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Mountain - Prairie
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Mountain - Prairie Colorado | Kansas | Montana | North Dakota | Nebraska | South Dakota | Utah | Wyoming
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-16-2005, 05:41 PM   #1
fast idle
CF Senior Member
fast idle's Avatar
takes about an hour, i once trained a chicken to do it , but he kept dropping the wrench lol mike
fast idle is offline   Reply With Quote
Old 01-20-2005, 09:38 AM   #2
3pedal_z06
CF Senior Member
3pedal_z06's Avatar
Send a message via AIM to 3pedal_z06
I think the valve cover gasket is the easiest gasket on the engine to replace. All you need is a wrench, some RTV and the gasket. Chicken is optional, beer is mandatory.
3pedal_z06 is offline   Reply With Quote
Old 01-20-2005, 10:04 AM   #3
RichD1986
CF Senior Member
RichD1986's Avatar
I'll have to give it a shot (and a beer). Some how-to book I read said the driver's side will test your patience with stuff that has to be removed. One shop said the right side takes about 1 hour while the left takes 4 hours. If I do it myself I might as well refinish the covers - they're looking pretty shabby. But, since I don't a lot of mechanic'ing, I always worry about taking something apart, not getting it back together right, and then having to sell it for parts on Ebay
RichD1986 is offline   Reply With Quote
Old 01-20-2005, 11:05 AM   #4
3pedal_z06
CF Senior Member
3pedal_z06's Avatar
You can sell anyting on eBay, so you will be able to get rid of it.
You could always take a picture or two of the stuff on the valve covers before you start. I am about to swap a carb manafold and valve covers on one of may cars, and I am going to try to draw a quick diagram of every thing. My problem is some things are already disconnected.
What year is it?
Old 01-20-2005, 01:55 PM   #5
OleDog
CF Senior Member
OleDog's Avatar
Quote:
L98 C-4's can be a bioch.
Alt bracket in the way
WW motor in the way.
It's not just 4 centerbolts on each side and you're done.
Not really technical, just time consuming.
OleDog is offline   Reply With Quote
Old 01-21-2005, 12:35 AM   #6
RichD1986
CF Senior Member
RichD1986's Avatar
I have the older cast heads, so not the 4 center bolts, but the 4 perimeter bolts. I can see where it would be difficult, and not being mechanically sharp (or patient) adds up to going to a shop.
Old 01-21-2005, 10:02 AM   #7
Glasman66
CF Senior Member
Glasman66's Avatar
Send a message via AIM to Glasman66
I'll help you if you want, I heard you mention beer!
It can't be too bad.
Glasman66 is offline   Reply With Quote
Old 01-26-2005, 11:04 AM   #8
3pedal_z06
CF Senior Member
3pedal_z06's Avatar
Count me in as well, if you need/want extra help. Just be warned, I'm slow, but I do poor work.
Old 01-28-2005, 12:25 AM   #9
RichD1986
CF Senior Member
RichD1986's Avatar
Quote:
Thanks, Guys - I may take you up on the offer if I run into trouble. I thought I'd try to remove the covers and refinish them before reinstalling. There was an article in corvettemagazine.com on removing and refinishing. The paint on mine is flaking and bubbling - generally pretty shabby - and I didn't want to do the gaskets without improving the appearance. Yellow valve covers with yellow sparkplug wires might nice BTW - does anyone know where I can get the covers media/bead blasted in the Aurora area?
Old 01-28-2005, 08:44 AM   #10
arrow322
CF Senior Member
arrow322's Avatar
Rich let me talk to a buddy of mine he does small sand blasting jobs in his garage and I'm sure he wouldn't have a problem doing it for a beer
I will call him tonight
Frank
arrow322 is offline   Reply With Quote
Old 01-28-2005, 09:34 AM   #11
3pedal_z06
CF Senior Member
3pedal_z06's Avatar
Frank
If that doesn't work, I have a small blasting cabinet in my garage. I will have to check to see if valve covers will fit in it.
Old 02-01-2005, 10:53 AM   #12
arrow322
CF Senior Member
arrow322's Avatar
Rich
Sorry for the delay in getting back to you, my friend said he can sand blast your valve covers just let me know if you want it done and we'll make arrangements.
Frank
303-594-1972
Old 02-02-2005, 12:19 AM   #13
RichD1986
CF Senior Member
RichD1986's Avatar
Hi Frank - Thank you for getting back to me on the bead blasting. I've had a problem with the car - it wouldn't start for the past 2 weeks. I finally got it going tonight, so hopefully, it's back up and running for a while. This past weekend I tried to start on the valve covers but discovered a big problem - there are 2 T-40 torx screws that attach the EGR pipe to the manifold. They are absolutely frozen tight in place and won't budge . The pipe, of course, sits in the worst possible spot - right over the cover. I tried WD, penetrating oil, hitting the screws with a hammer to loosen them, and let the engine run for a long while tonight hoping the heat would help. Right now I'm stuck. Getting those screws out will be my next projeect, but I need to do it without shearing off the heads. Hopefully, good news to follow soon -
Old 02-02-2005, 05:24 PM   #14
arrow322
CF Senior Member
arrow322's Avatar
If you need some help Rich let us know what we can do, but it sounds like you've tried just about everything..can you get a torch in there to try and heat it up? if so I have one if you don't
Frank
Reload this Page How much to install valve cover gaskets?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Gee... Totally forgot... bogus C4 General Discussion 58 07-06-2005 04:07 PM
1989 l98 valve adjustment jerrys 1989 C4 Tech/Performance 9 02-27-2005 07:20 AM
Installing 1.6 RR...easy or not? 94brick C4 Tech/Performance 20 11-24-2004 04:44 PM
Another bad AFR experience 87Z-ya C4 Tech/Performance 33 09-25-2004 02:51 AM
Supermaxx Header Install - Day 2 (of 2) Long with a ton o' pics! DT C5 Z06 Discussion 12 04-07-2004 02:26 PM
SuperRam Gaskets aren't gettin' it done. Use Permatex? B84RADR C4 Tech/Performance 34 08-30-2003 09:15 AM
AFR 190 Heads Just Placed an Order - Anybody Like these? more----> 85Procharged383 C4 Tech/Performance 11 06-05-2003 07:27 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
