Bobby,
Your problem is going to take some diagnostics. The statement by R94LT1 could be correct. The first thing you need to do is find out if you have a fuel problem or a spark problem. Depending on what you find you need to go thru certain steps to find out exactly what the problem is. If you do not have the technical expertise I suggest you have a GOOD technician look at it. The parts for this car are too expensive to guess at, you want to be sure. If you don't know of any mechanic in your area who is competent on a Vette I suggest you talk to someone in your local Corvette Club as they should know of some.
Good Luck,
Bob
