Corvette Forum
Go Back   Corvette Forum > Professional News, Articles, and Tips > Ken's Newsletters
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-03-2006, 03:36 PM   #1
Mr. Z
Junior Member
Default CorvettePartsBob any information? Brake pad wear sensor which way is it?
CorvettePartsBob,
Can you please clear up this confusion once and for all.
There seems to be a discrepancy between the TSM and '04 C5s as to the orientation of the brake pad wear sensors. The TSM states that the wear sensor is installed on the inside brake pad in the trailing position during forward rotation of the rotor (or top of the caliper on the front brakes) but I have checked an 04 Z06 and an 04 coupe and both have the wear sensor mounted in the leading position (bottom of the caliper on the front brakes). I'm sure that the factory did not get this wrong on that many cars and I suspect it has more to do with the design of the wear sensor itself. The reason I suspect the design is I checked an 01 coupe and it was in the trailing position however the wear sensor was of a different design. In the picture link below the pad on the left is the new design off of a 04 Z06 and the pad on the right has a design similar to an 01 coupe.
Of course if you check your brakes often and never get down to the wear sensor then the position of it is somewhat of a moot point but I was just curious since I have seen some posts on this forum and others questioning this very thing.
Mr. Z is offline   Reply With Quote
Old 03-17-2006, 08:30 PM   #2
CorvettePartsBob
Premium Supporting Vendor
CorvettePartsBob's Avatar
I have checked on directions with both OE and the Ceramic brakes, talked to our lead tech and compared to two C5's. The brake instructions with the OE and Ceramic pads, whose designs happen to match the RH pad in the picture, just say to put the pad with the wear sensor on the inside position only, no reference to top or bottom of the pad. My technician says the reason no mention of the sensor other than on the inside position is it actually makes no difference. The sensor is strictly a wear sensor and will work in either position. He said he always puts them on in the same direction as the pads being replaced. We checked two C5's with the original factory pads still on them and the front brakes had the sensor at the top inside and the rear pads had the sensor on the lower inside of both cars. So if you want it the way the factory does it there you go.
I hope this answers your questions.
Bob
CorvettePartsBob is offline   Reply With Quote
Old 03-20-2006, 01:08 PM   #3
GOLD72
CF Senior Member
GOLD72's Avatar
That would put the wear sensor in the trailing edge position for both front and rear wheels which makes sense to me. If the pad tries to wear in a tapered fashion, then the trailing edge normally will be the thinnest.
GOLD72
GOLD72 is offline   Reply With Quote
Old 03-20-2006, 07:22 PM   #4
Mr. Z
Junior Member
Thanks for the answers Bob.
Reload this Page Brake pad wear sensor which way is it?
Tags
2000, bottom, brake, correct, corvette, direction, indicator, installed, pad, pads, sensor, sensors, tapered, top, wear
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Electronic Service Manuals? BQuicksilver C5 General 29 11-27-2004 06:53 AM
Corvette Parts News! New C6 Section! 8/28/04 CorvettePartsBob Ken's Newsletters 9 10-05-2004 12:23 PM
When do get new brakes dallasvette C5 General 18 09-18-2004 01:19 PM
Low dust brake pads leolufse C5 Tech 10 08-16-2002 10:19 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
