Corvette Forum
Go Back   Corvette Forum > Professional News, Articles, and Tips > Ken's Newsletters
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-23-2005, 07:16 AM   #1
xraymdr
Junior Member
Default premium gas
In view of the current high gas prices, especially where I live in California, will it ruin my car if I do not use premium gas?
xraymdr
xraymdr is offline   Reply With Quote
Old 04-23-2005, 09:50 AM   #2
BobA
CF Senior Member
BobA's Avatar
Quote:
xraymdr
High test is expencive BUT DETINATION is more expencive if you burn pistons with regular.
BobA
__________________
87 Buick GN 11.70@116
91 Syclone 12.38@108
01 Buick GS (wife) 14.37@98
03 Z06 ET 11.80@118.03
05 GMC Crew Cab Dually Duamax and Allison no time yet
Piper Arrow STOL
06 Harley Heritage Classic BIG BORE
BobA is offline   Reply With Quote
Old 04-23-2005, 10:30 AM   #3
tmjvett2009
CF Senior Member
St. Jude Donor '09-'10-'11
tmjvett2009's Avatar
If you cant afford a little more for the good stuff then maybe you need to sell your car
tmjvett2009 is offline   Reply With Quote
Old 04-23-2005, 11:09 AM   #4
Ken Fichtner
Premium Supporting Vendor
Cruise-in I Veteran
Cruise-in II Veteran
Cruise-In III Veteran
Ken Fichtner's Avatar
Good morning,
I have always recommended that owners follow the guidelines printed in their owner's manuals. The engineers have designed new vehicles to perform at a specific level and to attain a specific MPG. Damage caused by using the wrong fuel or by lack of maintenance will not be covered by the warranty and in the long run will cost much more than paying the price up front.
Ken Fichtner
Ken Fichtner is offline   Reply With Quote
Old 04-23-2005, 11:23 AM   #5
BobA
CF Senior Member
BobA's Avatar
Quote:
Originally Posted by Ken Fichtner
Good morning,
Ken Fichtner
BobA
__________________
Piper Arrow STOL
Old 04-23-2005, 02:50 PM   #6
double eagle
CF Senior Member
double eagle's Avatar
Isn't a C6 worth premium fuel? I think so.
double eagle is offline   Reply With Quote
Old 04-23-2005, 04:05 PM   #7
redvett01
Junior Member
GM factory fills each and every gas vehicle it builds with unleaded regular and all there fleet vehicles get regular. If driven in normal conditions the PCM & knock sensor will just retard timing. When the weather is cold below 60 deg there is none or little retard in timing.
In the owners manual of my 94 ZR-1, 01 C5 & 04 Monti Carlo SS Supercharged it says "Quote" use 91 octane but you can use mid or regular BUT performance will be reduced, if spark knock occurs increase octane but if 91 dosent eliminate knock vehicle needs to be serviced by your dealer.
redvett01 is offline   Reply With Quote
Old 04-23-2005, 05:05 PM   #8
coolcat
CF Senior Member
coolcat's Avatar
Quote:
Originally Posted by redvett01
GM factory fills each and every gas vehicle it builds with unleaded regular.
So every C6 that rolls out of BG has it's tank filled with UNLEADED REGULAR gasoline???
coolcat is offline   Reply With Quote
Old 04-23-2005, 06:42 PM   #9
Shylor
CF Senior Member
Shylor's Avatar
C4's, C5's and C6's can safely use regular unleaded fuel. It's in the owner's manual.
Shylor is offline   Reply With Quote
Old 04-23-2005, 07:48 PM   #10
Mark923
CF Senior Member
Mark923's Avatar
Location: Wetumpka / Nashville / Holly Springs - Alabama / Tennessee / Georgia
xraymdr
Here's the Owners Manual informaton about the fuel from page 5-5.
Fuel
Use of the recommended fuel is an important part of the
proper maintenance of your vehicle.
Gasoline Octane
Use premium unleaded gasoline with a posted octane of
91 or higher for best performance. You may also use
middle grade or regular unleaded gasoline rated at 87
octane or higher, but your vehicle’s acceleration may be
slightly reduced. If the octane is less than 87, you may
get a heavy knocking noise when you drive. If this occurs,
use a gasoline rated at 87 octane or higher as soon as
possible. Otherwise, you might damage your engine.
Gasoline Specifications
It is recommended that gasoline meet specifications
which were developed by automobile manufacturers
around the world and contained in the World-Wide Fuel
Charter which is available from the Alliance of Automobile
Manufacturers at www.autoalliance.org/fuel_charter.htm.
Gasoline meeting these specifications could provide
improved driveability and emission control system
performance compared to other gasoline.
California Fuel
If your vehicle is certified to meet California Emission
Standards (see the underhood emission control label), it
is designed to operate on fuels that meet California
specifications. If this fuel is not available in states
adopting California emissions standards, your vehicle
will operate satisfactorily on fuels meeting federal
specifications, but emission control system performance
may be affected. The malfunction indicator lamp may
turn on and your vehicle may fail a smog-check test. See
Malfunction Indicator Lamp on page 3-41. If this
occurs, return to your authorized GM dealer for
diagnosis. If it is determined that the condition is caused
by the type of fuel used, repairs may not be covered
by your warranty.
Good luck!
Mark923 is offline   Reply With Quote
Old 04-23-2005, 11:22 PM   #11
BBCC
Junior Member
I agree......
BBCC is offline   Reply With Quote
Old 04-24-2005, 03:44 PM   #12
rm50
CF Senior Member
rm50's Avatar
Hopefully your were kidding. If the price of gas worries you then you should drive less but use the good stuff. I guess you will have more time to Zaino the car/
rm50 is offline   Reply With Quote
Old 04-24-2005, 07:18 PM   #13
xraymdr
Junior Member
Thanks for the useful information
xraymdr
Old 04-26-2005, 09:46 AM   #14
MANECDA
Junior Member
Figuring a difference of 20 cents per gallon between regular nad premium, you would only be saving $2-$3 a a tankful. Not worth it to me.
MANECDA is offline   Reply With Quote
Old 04-26-2005, 12:44 PM   #15
Tom/99
CF Senior Member
Tom/99's Avatar
I'll stick with preminum.
Tom/99 is offline   Reply With Quote
Old 04-27-2005, 01:39 PM   #16
77TSi-meez
CF Senior Member
77TSi-meez's Avatar
Yep
77TSi-meez is offline   Reply With Quote
Old 04-27-2005, 04:19 PM   #17
desertapache
Junior Member
My wife used regular in her C5 and you could tell the difference. I agree premium is the only way to go. I use premium in all my classics.
desertapache is offline   Reply With Quote
Reload this Page premium gas
Tags
2003, corvette, gasoline, premium, wwwautoallianceorgfuelcharterhtmgasoline
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Your Brand Of Premium Gas? nmbsun C5 General 43 06-29-2005 12:24 AM
Your Brand Of Premium Gas? nmbsun C5 Tech 28 06-28-2005 09:41 PM
Is most premium gas contaminated? corvetteronw C4 General Discussion 24 03-12-2005 06:13 AM
Highest price seen for Premium Gas in Southeast? Z06-Nomad Southeast 25 02-24-2003 06:12 AM
Does a C4 need premium gas, Can you use regular???? a1970stingray70 C4 General Discussion 40 01-13-2003 10:45 PM
Premium Gas? jdog0411 C4 General Discussion 53 10-24-2002 12:21 AM
Whats the cost of premium gas where you are? How much $ does it take to fill? TrplBlk01 C4 General Discussion 23 08-05-2001 12:15 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
