C5 DIC problem.
C5 DIC problem.
2001 coupe. All segments of the vacuum florescent display are on. Reset shows some changes. Disconnected battery for 20 min. Key on removed fuses 16 and 23. Key off replaced fuses. Parking light switch shows the same problem. Thanks. Bob.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. C5? That's covered under the C5 Corvettes, 1997 - 2004 section:
https://www.corvetteforum.com/forums...s-1997-2004-2/
Got a technical question about the C5? Use the C5 Technical section:
https://www.corvetteforum.com/forums/c5-tech-1/
General question? There's a C5 General Section:
https://www.corvetteforum.com/forums/c5-general-103/
We encourage new members to take some time to browse around the site and read the Announcements and Stickies as they contain important and frequently asked information.
Thank-you
