Constantly asked to log in again, again
As I follow a thread, I'm required to log in again every time I open a new page. What have I done wrong?
The logging in issue is a cookie issue with your browser.
You'll need to remove all CorvetteForum cookies. Logging out is not the same and won't work. If you have CorvetteForum marked as a favorite and if you use the browser's script to remove cookies, you'll need to deselect the Preserve Favorites option or the data won't be removed. Then revisit the forum, use the Remember Me option, and log in. This issue is not uncommon and because websites generally use several cookies, this issue generally only occurs on one site at a time.
If that doesn't fix the issue then you have some 3rd party security software deleting or interfering with the cookies, your browser isn't allowing cookies, or your browser is deleting cookies upon exist.
