"Duplicate" message
"Duplicate" message
I just got a message that said the response I posted was a duplicate of one that I posted in the past 5 minutes. I wasn't even logged on to CF 5 minutes earlier. I get these messages often. What gives? Also, lately I sometimes have to log in 3 or 4 times before it registers.
JT in the HELP forum can probably help you with this one. Thread moved from C6 General.
He's also the man to help you with other forum things of this nature.
Is this for the mobile app?
The logging in issue is a cookie issue with your browser. The duplicate error message is something else.
You'll need to remove all CorvetteForum cookies. Logging out is not the same and won't work. If you have CorvetteForum marked as a favorite and if you use the browser's script to remove cookies, you'll need to deselect the Preserve Favorites option or the data won't be removed. Then revisit the forum, use the Remember Me option, and log in. This issue is not uncommon and because websites generally use several cookies, this issue generally only occurs on one site at a time.
If that doesn't fix the issue then you have some 3rd party security software deleting or interfering with the cookies, your browser isn't allowing cookies, or your browser is deleting cookies upon exist.
