NEW PHOTOBUCKET picture posting directions
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,323 Likes
OK, some people are having trouble with the new version of Photobucket. It doesn't give the automatic "drop down" menu under the uploaded photos, but it still works the same.
Here's a quick update. NOTE: I assume that you have joined Photobucket (for free) and already uploaded your photos. I am starting at the page where you have opened your Library in the NEW Photobucket:
Here is your opening page, showing your photos:
This is what shows when you click on the photo you want to post:
This is the bottom right corner of the same page- it shows the links avialable- you can see I have my cursor on the BOTTOM link, otherwise known as the IMG link:
This is what happens/ what it looks like when you click the IMG link- it turns yellow and says "COPIED"
Now you go to the Forum, and in the box where you are making your post, you PASTE the link you just copied. The link should look like this:
You make your forum post and SUCCESS!!!! It looks like this:
If it doesn't work, you did one of these steps wrong.
I personally like to use www.shutterfly.com which is also free and has step by step instructions.
You can post multiple pictures at a time by repeating the process. Each picture needs its own IMG tag.
For example:
[img]https://www.corvetteforum.com/forums/images/misc/c4.jpg[/img]
[img]https://www.corvetteforum.com/forums/images/misc/c5.jpg[/img]
Will do:
For example:
Will do:
For those who have apple products, as I do, there is a slight difference that allows it to work for me on my iPad. When I go to the "IMG" link, I click on it -- sometimes have to do this twice, then the "Select All" tab appears right above the IMG link, then I click on "Select All." Then I go to the center of the page and click on the "Copy" tab that pops up. Then I go to the reply area of the forum I want to reply/post a picture on, then hit "Paste."
This is a little difficult t the beginning, because there are multiple steps that you need to do in order, but now works well after learning the steps and posting pictures several times.
3rd Gear
where is photobucket or how do i obtain photobucket? Thank you
