You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
I have sized this avitar every size and KB and I still can't load the avitar. I even tried to reload the one I had and it will not load either. Can somebody help? I tried all of these, all less than 28kb and all smaller than 150 pixels.
Don't worry, it is not you, I am the self proclaimed "King of the Avatars" and I have not been able to change mine for three days!!
The forum is having issues!
If you had posted this in the HELP forum, you would probably have discovered the thread there about others having this same problem. There is currently a forum problem with changing avatars.
Revisit the HELP forum in another day or two to see if it's been fixed yet.
I did a forum search and also a google search on the site for an avitar problem, not avatar. I guess it helps if you spell it correctly. Otherwise, thanks for the advice.
Don't worry, soon enough you will have your nice Vette as your avatar and I will have a new HOT BABE as mine!!!
However, the HELP forum is for use with any problem you're having with the forum. There have been members who have been here several years that didn't know it existed or didn't know what it was for. I wasn't trying to be a smart *** about it, just wanted you to know it was there and what it was for. Always good to go there first if it seems to be a forum problem. JT in that forum can fix just about anything.
