When you view the Garage's front page:
http://forums.corvetteforum.com/garage/
You should see the Top Rated Vehicles section as well as other sections. This appears to be accurate.
What I think the issue you're reporting, and seeing, is that when you click on the "See more" link in the Top Rated Vehicles section, you're seeing vehicles that haven't been rated. This is because that link shows you all entries with a sorting order of most recently updated, first.
This appears to be the design of the plugin as I've verified this plugin is behaving the same way on another vBulletin forum.
