A little know fact, as I've helped many with this very same issue, is that if you change the skin in your UserCP it becomes "permanent" to your account as it's the default skin. This means all devices that you use to access the forum, using the account, will have that skin that you selected. However, it can be overridden per device.
If you change the skin via the drop-down menu in the bottom left corner of each page, it will only apply to the device you're using as it's cookie/session based.
In addition, you can even bookmark the mobile skin in your mobile phone for easier browser.
What should be done, is there should be a link placed in the Mobile theme skin to get people out of the Mobile theme skin who aren't tech savvy to be able to figure it out.
Thanks JT, I didn't know about the drop down menu in the lower corner of the page. Thats what I must of hit accidently, booting me out of the standard format. I was able to fix my problem using your extremely helpful explanation in the "help forum"
