I wanted to add a couple facts to my sig. and it said I was over the 500 mark. I went back and deleted about 15 letters (didn't add anything) and saved again and it still stated I was over the mark. Didn't make sense to me??
__________________
1989 383
Fully ported alum. heads,stainless steel 2.00/1.56 severe duty valves,tpi valve springs, titanium retainer,forged speed pro pistons, 10.5:1 callies steel crank, 6.75" Dia. harmonic balancer,Hyd roller block,Superram plenum runner kit,Superram base,58mm throttle body,Hyd roller Tpi camshaft 219/219@50, 1.6 ratio stainless steel roller rocker arms,plasma moly speed pro rings,Hyd roller lifters,Hurst Line Loc
Best run: 11.85@119.65mph
Location: Knoxville Tennessee Oak Ridge National Laboratory
Quote:
I counted 495 without the syntax to do your sig pic. So your total character count may still be over 500.
An Administrator would need to verify, but the character limit in the signatures has two entries. One including BB markup (BB markup being code used to make your image display, for example) and one excluding BB markup.
Depending on how the forum is setup, the code used to display your image may or may not be counting toward the character limit.
