That actually is the intended function.
When you select Remember Me, you're given a cookie and you will be remembered even if you close your browser (as long as you don't automatically delete cookies), or if become inactive after the "cookie timeout" as defined by the forum (generally 15-20 minutes). The "cookie timeout" is used to determine when a user is no longer active on the forum and is used as a point of reference to change all previous unread posts to read status.
If you don't select Remember Me, you are given a session (think temporary pass) which will only remain valid as long as the browser is open and as long as you remain active and don't go inactive long enough to trigger the "cookie timeout" (approximately 15-20 minutes). If you do, you're considered finished with the site and you lose your auto login. This feature is there for users who share computers (such as public accessible computers).
Quote:
Originally Posted by Berto
Solution is simple enough:
If I check the Remember Me box, I can log in. If I do not check this box, I cannot log in.
Whatever, I suppose.
