Corvette Forum
Go Back   Corvette Forum > Help & Feedback > Help Forum
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Help Forum How To | General Corvetteforum Questions | Feedback
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-19-2009, 10:17 PM   #1
2010c6
CF Senior Member
2010c6's Avatar
Default missing post
I made a post and it went missing, can members delete posts?
2010c6 is offline   Reply With Quote
Old 10-19-2009, 10:24 PM   #2
RicK T
CF Senior Member
RicK T's Avatar
I probably can't help you resolve this but maybe. No, members can't delete posts. You can delete the text of a post you made but no one else can delete your stuff but you can't delete the post itself. If you deleted the text, your user name and avatar would still appear but with a blank text field. Does that help?
What was the title the thread you posted to and what Forum?
RicK T is offline   Reply With Quote
Old 10-19-2009, 10:44 PM   #3
J T
Administrative Contributor
Yes, users can delete their own posts, though there is probably some restrictions on it.
In addition, due to the way the system is threaded, if a user deleted their post, and it happened to be a thread starter, it would take the entire thread and all replies with it. However, I do not believe a thread starter can delete their own posts.
It is possible a moderator moved or deleted the thread.
J T is offline   Reply With Quote
Old 10-19-2009, 10:52 PM   #4
JimTN
CF Senior Member
Support Corvetteforum!
JimTN's Avatar
A user cannot delete their first post if it starts a thread. Only a moderator or administrator can move threads or delete other users' posts.
JimTN is offline   Reply With Quote
Old 10-19-2009, 10:56 PM   #5
RicK T
CF Senior Member
RicK T's Avatar
Okay, are you saying something different than what I said or just saying the same thing I said but in a different way? I'm confused, which is not uncommon.
Old 10-19-2009, 11:13 PM   #6
J T
You had mentioned that users cannot delete their own posts itself. Users can in fact delete (some of) their own posts. You can delete either post you made in this thread as a test . I do not believe a user can delete their own post if it's the first post in a thread (topic starter/creator).
However, users cannot delete posts made by other users, unless that user happens to be an Administrator, Moderator or other staff member that has privileges above normal users. You did mention this and that I was not disagreeing with.
The only way to know for sure what happened here is to have an Administrator or Moderator find the post in question to see what happened.
Old 10-19-2009, 11:21 PM   #7
pewter99
Auctioneer Moderator
St. Jude Organizer
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
pewter99's Avatar
You can delete your post IF no one else has replied.
Thats it....otherwise you can delete the text but not the whole post.
As to the OP's problem...perhaps it was moved and not deleted. I will look
pewter99 is offline   Reply With Quote
Old 10-19-2009, 11:22 PM   #8
RicK T
CF Senior Member
RicK T's Avatar
Thank you, that was my understanding all along.
Old 10-19-2009, 11:23 PM   #9
pewter99
St. Jude Organizer
pewter99's Avatar
I see you had a post removed by Moderator "Tact"....PM him and ask why.
Old 10-19-2009, 11:23 PM   #10
pewter99
St. Jude Organizer
pewter99's Avatar
no problem. If you want something totally removed ask a Mod and we can make it go away
Old 10-19-2009, 11:35 PM   #11
JimTN
CF Senior Member
JimTN's Avatar
I once tried it as a test post in the Testing forum and it would not let me delete the post that started the thread, even though no one else had posted to it.
It's been several months ago, so maybe things have changed since then.
Maybe I just have fewer capabilities on the forum than others.
Old 10-20-2009, 12:31 AM   #12
J T
There is more to it than that. At the time of these posts in this thread, it was not made known if the person in question was the topic creator or simply responding to an existing thread. I (attempted) to describe the difference between a reply and a thread creator and the permission differences likely existing. I was a bit loose with my wording because vBulletin has a lot of permission levels and customization. It's possible there are a few forums here on CF that aren't consistently set, permission wise, and thus a user can delete their posts (a reply post) in one forum while being unable to do so in another forum. That might explain why Jim cannot delete a post in the Testing forum, as he stated and why there appears to be some mismatched results.
I was able to completely remove a past post I made in the Classifieds. Not just delete the content, but I had a "Delete" button and it deleted just fine. I was also not the thread creator. And I was one of several replies in the thread.
In addition, I have the option to remove a post I made in this thread:
Old 10-20-2009, 01:01 AM   #13
J T
I don't mean to nitpick here, but you first had stated that "you can't delete the post itself", and that was why I replied the way I did:
Of course, this could all have been a misunderstanding between topic creator, and responder. Which I attempted to address from the start as they do have different permissions and the outcome/answer is different!
Old 10-20-2009, 01:18 AM   #14
JimTN
CF Senior Member
JimTN's Avatar
I should have been a little more explicit. I can delete posts that I make in threads in 3 or 4 different forums. The only post of mine that I could not delete was the post that created a new thread in the Testing forum. I'm pretty sure I could have deleted the content of that post, but I think the title would still have remained.
Old 10-20-2009, 01:29 AM   #15
J T
Jim, the permissions in vBulletin can be quite hairy, especially if it's Custom permissions per forum per usergroup, rather than using the default permissions per usergroup for each forum. From what you describe, it does sound to me that a few forums may not be consistently setup, permission wise, and hence why there is some different results, experience and answers given. Of course, as you said, it could also be things have been fixed since your last findings.
Old 10-20-2009, 08:33 AM   #16
pewter99
St. Jude Organizer
pewter99's Avatar
an individual post yes...a thread no if there are replies and just because you delete it doesn't mean it is gone
Old 10-20-2009, 09:24 AM   #17
2010c6
CF Senior Member
2010c6's Avatar
Thank You
All I did was ask a question about the product for sale. Since the product overrides a safety feature in the car I just asked it that was a good idea?
Old 10-20-2009, 09:42 AM   #18
pewter99
St. Jude Organizer
pewter99's Avatar
Quote:
Originally Posted by 2010c6 View Post
Thank You
yeah I cannot speak for him and I haven't read the thread. If you PMd him I am sure he will get back with you.
Reload this Page missing post
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
IMPORTANT ELECTRICAL INFORMATION (Long!) Bill Curlee C5 Tech 1182 01-26-2012 08:48 PM
Seeking Corvettes at Carlisle feedback --> racelance National Events 119 03-31-2006 11:15 AM
Post now your C6 Z06 predictions. Scissors C6 Z06 Discussion 70 12-28-2004 12:18 AM
OT...I miss the post counter.... mbeeman350 C3 Tech/Performance 58 11-15-2004 12:31 PM
Header Shoot Out Post your before and after dyno numbers and Vote extremecorvette C5 Tech 74 08-22-2003 12:49 AM
4-Post Lift Collapse - Perfect Park 7000. (4 months later its getting nasty) 69L71 C3 Tech/Performance 114 08-21-2002 09:27 AM
4-Post Lift Collapse - The Probable Cause 69L71 C3 Tech/Performance 30 04-08-2002 08:54 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
