Thoughts on the garage
Not for me. Any way to delete or suppress the Notice after I've read it at least once?
BTW, when I click on the first link in the ANNOUNCEMENT at the top of the page to get details about it, I get a "Page Not Found" error message.
Tried to add a car and it wouldn't allow me.
I filled it out completely, but when I submit, it had a red note about required info.
Nothing was highlighted as missing...all fields were filled out.
I put my car in the garage....but i cannot find an edit portion to add or delete....
jack
jack
http://forums.corvetteforum.com/garage/
It should give you links to edit and delete at the top
If you don't want to call your car Megan Fox, you are more than welcome to call it by its model name
No - if you would like to post more than one, go here:
Click on "add pictures"
Although after clicking on "add pictures" I had to search a bit as the next step isn't labeled. Just a little symbol off to the left that I almost missed.
Thanks for the help.
Your submission could not be processed because a security token was missing. If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error.
I tried to add pics to my garage. I will try again later.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
I agree with others... requiring a "nickname" is silly IMO. That should be optional. It prompted me to simply enter "None" for both my vehicles; but since I've done that, it created new problems. Now, each vehicle has the same album name and so the pictures I uploaded of my 2nd vehicle are hiding in the void. Whenever I click on my 2nd vehicle, I get linked to my first vehicle. because both albums have the same name. Are the album names based on what one types into the "nickname" field?
