HOWTO: Embed Youtube Videos.
Cruise-In 8 & 10 Veteran
St. Jude Donor '08, '15
This is a HOWTO designed specifically for the CorvetteForum Help Section on how to properly embed a flash video from YouTube in your posts and threads.
Step 1: Find the video you wish to embed. For this one, I've chosen WOEII's RaceRock video he recently posted in the Off Topic Section:
Step 2: Look at the URL on the YouTube page which should look something similar to this:
Step 3: Either start a new thread, or click reply on an existing one and then copy the text following the http://www.youtube.com/watch?v= which will look something along the lines of this into the new page that comes up:
Step 4: Paste the text into your post and then place the forum YT Code around it which will look like this:
Note: The leading part of the YT code will look like this: and the trailing part of the code will look like this: so the final product looks like this:
It's not unlike HTML where you have to “open” and “close” your code so the forum software knows what to do with it.
Step 5: Click submit on the bottom of the page, and your post should look something like this:
Voila! You've successfully embedded a YouTube video in your post.
I'm trying to embed a slideshow from photobucket and only getting a clickable thumbnail whcih take you to the PB page the slideshow is on....we don't want that...we want the slideshow to automatically play will that same [yt] code work with slideshows as well?
Sorry for the hijack...i've been at this for hours!!!!!
04 commemorative - I'm not exactly sure where you're confused. You simply type and around the part of the URL on youtube I pointed out earlier.
If my computer does not recognized YT tags, what am I missing? Do I need a YouTube account for this to work? Or, a certain version of OS? Or, a patch? What?
gp
gp
If you go directly to the YouTube website, does the videos work? What are you seeing, or not seeing, here on CF forum?
The "yt" tags are what's known as BB codes and codes like these are enabled by forum administrators for use by the members. Not all forums are set up to use all of the various BB codes.
So it's not your computer, it's the forum software that allows embedding of YouTube videos. And you should be able to embed almost any YouTube video once know what the URL/filename is as theanswerwriz42 pointed out. You don't have to have a YT account.
As far as a PowerPoint slideshow, you just need to embed the PP link from PB and use the appropriate tags (IMG??). Some PP slideshows will automatically start or others start once you click on the right arrow that is a ghost image at the lower left corner of the start page of the slideshow. Also some PP slideshow will keep running until you hit the ESC key or some will stop at the last slide. All depends on how the slideshow is set up.
The YT tag on CF is a simple HTML string. The user's computer still does the heavily lifting here, so to speak. The YouTube also still serves the content. The YT tag is just a "dumb" link, to be honest. YouTube and the user's computer does the work.
In addition, if using FireFox and a flash blocker (common since flash is often used for ads and can be CPU intensive), that also needs to be ensured it's checked and not disallowing the content.
Need more information.
I'm not 100% familiar with photobucket and the slideshow, but I tried to explain it here:
http://forums.corvetteforum.com/help...show-help.html
I don't think the member will be able to accomplish what they want because my quick photobucket tests did not appear to allow the slideshow to start without user interaction.
I can play YouTube videos just fine. When users post complete URL's vs the YT tags, I don't have any issue. It's when the YT tags are used (enclosing only the YT vid#) that it doesn't work. It's like my PC doesn't "know" what a YT tag is at all. And, I don't have tools to imbed them either.
Is this a "tool" available for certain accounts (as suggested above)? Possibly for paid members only????
BTW: As noted above, I don't have a "tool" to imbed YT tags. Simply put...My PC doesn't figure out that a YT tag means go to www.youtube.com and find the video ID listed inside the YT tag(s). It understands other tags like URL and IMG... just not a YT tag.
gp
gp
gp
gp
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/videostringhere"></param><embed src="http://www.youtube.com/v/videostringhere" type="application/x-shockwave-flash" width="425" height="350"></embed></object>
The above is what is known as HTML. However, Corvette Forum, like most other community based forums, does not allow HTML to be directly used and parsed for security reasons. To get around this, Administrators can take an HTML code and define it as a BB code. BB code is generally allowed and is safer because it's defined by the Administrators and is selectively used.
The only thing Corvette has done is convert some of that string to equal [YT][/YT] tag because HTML (which is what the above code is) is not allowed to be posted and it's not parsed. Therefore, Corvette Forum took the above HTML tag and rewrote it to equal [YT][/YT] tags.
What exactly are you seeing? Any error messages? Any shell boxes to show the YT video should be there?
My best guess is that you may have some 3rd party software blocking the request.
The vB software, in it's stock forum, does not allow the ability to turn off and on YT tags (BB code) for individual users or groups. It's completely different from the Attachment feature, which can be controlled on a usergroup level and is done so on this forum.
Therefore, if your browser doesn't understand this code, it's not your account, but rather your browser or some 3rd party software blocking it.
theanswriz42:
Great instructions. I tried various approaches to make the embedding work without success, and then found your post. Sweet!
Question:
CF apparently reduces the size of the YT vids. I have no idea why CF would do that - the YT vid should not use any CF bandwidth. And even large vids are smaller than the size of pics CF uses. So why does CF limit the size of vids?
Do you know of a workaround?
Here is a vid of my 53 #276 engine compartment. Looks small on the CF site. But if you double click on the YT video and go to the YT page, the vid is much larger.
Thanks for your help,
Russ
earlycorvettes.com
Question:
Russ
earlycorvettes.com
There is no workaround. CF defines the size as 425x350 in their YouTube tag. You can't alter that, nor can you use HTML to override it. This is something only the CF Admin could fix in the YouTube tag, but I'm guessing there is a reason why it's set at the size it is.
theanswriz42:
Question:
Russ
earlycorvettes.com
Question:
Russ
earlycorvettes.com
Thanks J T.
I see what you mean. I looked at the coding for this thread, and I see how yt-videoID-/yt translates into:
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/nlXMr15E14I"></param><embed src="http://www.youtube.com/v/nlXMr15E14I" type="application/x-shockwave-flash" width="425" height="350"></embed></object><br />
I wonder if the size limitation is more historical than anything else. I am not a huge YT user, but I suspect that the size of YT vids has increased over time.
I also wonder if the CF admin would be willing to increase the limit....
Russ
Russ
You can try to contact Savewave (Administrator) and see what he thinks:
http://forums.corvetteforum.com/memb...-savewave.html
Thanks J T.
Russ
Russ
Basically, you need a [yt] tag at the start, then the string in the middle, then a [/yt] tag at the end.
So, your example should look like:
[yt]BmUx0L6k_0U[/yt]
To recap:
1) [yt] at the start - ALWAYS
2) The "string" from the YouTube video, which in your case is BmUx0L6k_0U - this value will change depending on the YouTube video you're linking
3) [/yt] at the end - ALWAYS
To recap:
To recap:
To recap:
