Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Great Lakes
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Great Lakes
Illinois | Indiana | Iowa | Michigan | Missouri | Minnesota | Ohio | Wisconsin
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-16-2010, 01:37 AM   #1
ragtopws6
CF Senior Member
ragtopws6's Avatar
Default 99FRC Newb went from M12 to MM6
Well, 99FRC Newb sent me his tired M12 with some issues and had no 3-4 gears. When I opened it up, the 3-4 shift fork was broken. It had some other issues also so we decided to change the internals to MM6 set up. Here was how it was done.
This is how dirty the transmissions was.
The shift fork pads were in trouble.
The fork fingers were broken off!
The upgraded bronze fork pads and billet keys.
Billet keys installed.
Assembling main and counter shaft for setting end play.
Main case on to check for end play.
Everything assembled including steel 3-4 shift fork and ready for the main case for the last time.
Main case on, shifter rail on, cover on.
Ready to accept 5-6 and reverse.
5-6 drive and driven gears in.
Reverse gear and synchro on.
Tail shaft housing on and ready to be rowed through!
ragtopws6 is offline   Reply With Quote
Old 03-16-2010, 01:45 AM   #2
99FRC Newb
CF Senior Member
99FRC Newb's Avatar
Send a message via AIM to 99FRC Newb
in my defense: it was that dirty because i was running an open x-pipe!!!
99FRC Newb is offline   Reply With Quote
Old 03-16-2010, 01:50 AM   #3
ragtopws6
CF Senior Member
ragtopws6's Avatar
I believe you.
Reload this Page 99FRC Newb went from M12 to MM6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
