Racing Brake Fluid Comparison
Hey Crew
Thought this was a good Comparison of HP brake fluids and some average prices. Their are a couple new ones out their with some High Temps without the price tag of Castro SRF, But that being said Castro SRF is still the best!!!!
AP Racing 551
DOT 3 527°F (275°C) 302°F (145°C) $12.50/16.9 oz
AP Racing 600
DOT 3 590°F (310°C) 410°F (210°C) $18/16.9 oz.
AP PRF Racing Brake Fluid
DOT 4 608 (320ºC) 311 (155ºC) $29/16.9 oz.
ATE Super Blue
DOT 4 536°F (280°C) 396°F (194°C) 9.75/liter
ATE Super 200 (amber color)
(aka Type 200)
DOT 4 536°F (280°C) 396°F (194°C) $9.95/liter
Bosch DOT 3
DOT 3 491°F (255°C) 288°F (142°C) -
Bosch DOT 4
DOT 4 509°F (265°C) 329°F (165°C) -
Bosch DOT 4+
DOT 4 536°F (280°C) 356°F (180°C) -
Brembo LCF 600+
DOT 4 601°F (316°C) 399°F (204°C) $29/16.9 oz.
Brembo Sport EVO 500+
DOT 4 520°F (271°C) 336°F (169°C) $13/16.9 oz.
Castrol SRF
DOT 4 590°F (310°C) 518°F (270°C) $64/liter
Castrol GT LMA
DOT 4 446°F (230°C) 311°F (155°C) $4/12oz.
Ford HD (C6AZ-19542-AB)
DOT 3 550°F (287°C) 284°F (140°C) $6/liter
GS610 Brake Fluid
DOT 4 610°F (321°C) 421°F (216°C) $40/liter
Gunk (Berryman) DOT 4 HD
DOT 4 510ºF (266ºC) 311ºF (155ºC) $2.49/12 oz.
Motul DOT 5.1
DOT 5.1 509ºF (265°C) 365ºF (185°C) $6/ 1/2 liter
Motul Racing Brake Fluid 600
DOT 4 594ºF (312ºC) 421°F (216°C) $15/half liter
Neo Super DOT 16
DOT 4 610°F (322°C) 421°F (216°C) $13/12 oz.
Pentosin Super DOT 4
DOT 4 500°F (260°C) 338°F (70°C ) $14/liter
Pentosin Racing Brake Fluid
DOT 5.1 572°F (300°C) 392ºF (200°C) $18/liter
Performance Friction Z-Rated
DOT 3 550°F (287°C) 284°F (140°C) $7.95/16 oz.
Valvoline SynPower
DOT 3/4 527ºF (275ºC) 347ºF (175ºC) $5/12 oz.
Wilwood Hi-Temp 570
DOT 3 570°F (299°C) 284°F (140°C) $6/12 oz.
Wilwood EXP600 Plus
DOT 4 633°F (330°C) 417°F (213°C) $20/16 oz.
AP Racing 551
AP Racing 600
ATE Super Blue
(aka Type 200)
Bosch DOT 3
Bosch DOT 4
Bosch DOT 4+
Brembo LCF 600+
Castrol SRF
Castrol GT LMA
GS610 Brake Fluid
Motul DOT 5.1
Neo Super DOT 16
Valvoline SynPower
Wilwood Hi-Temp 570
Wilwood EXP600 Plus
Location: If you don't weigh in you don't wrestle Road America
I perfer the Wilwood EXP 600, a nice mix of price and performance.
If your looking for info on Wilwood or StopTech kits I have some good track tested info from some friends that run Road America regularly.
Cruise-In III Veteran
St. Jude Donor '06-'07-'08
I used to run Motul 600 and NEVER had that type of issue with boiling brake fluid, even after running 5 or 6 30 minute sessions in 90+ degree temperatures on a fairly heavy-braking track (this of course assumes bleeding the brakes prior to the track day). I've since switched to SRF primarily because I can "cheat" a little bit more on bleeds between track days. If I go out for a short day (just a couple of sessions) I don't need to bleed the SRF before the next heavy duty track day, but I probably would have to with the Motul or risk running into a soft pedal by the end of the day.
just going by what he told me..maybe he didn't bleed out all the way?
had a c6 do the same thing with his stock dot3. both guys were faster than anybody else on the track and we were hitting 145 mph..so lotsa brakes going into the turn i am having pretty good luck with castrol dot 4 but i am easy on brakes, i hate to spin out
