Why does no one answer the phone? And no voice mail service? A friend of mine is looking for a dyno tune on his 92, yet can't get a hold of anyone to talk to.
Could you send me a pm with his contact info or have him call Matt Reese at 313-561-5500 ex. 1303. This is his direct line and there is a voice mail if he is on the other line. I'd like to apologize for you not being able to get through and will look into it.
Regards,
Rick LeBlanc
Livernois Motorsports
__________________
Click here to check out Livernois Motorsports on YouTube
Your LS-Series Engine Specialists! CNC Cylinder Heads, Rotating Assemblies, Short Blocks, Performance Parts, Dyno Services, Fabrication and Machine Shop Services
Good question canar, I take it these are LS6 heads that are ported, polished and decked? The rocker assembly is reused? Could this be done using Halltech's "new and improved" intake? Sounds like the stock LS6 heads can be traded for upgrades, would those heads and LS6 cam be of interest to LSX owners here? Lastly Should the 1-7/8" headers be used or are the 1-3/4" tubes recommended? Thanks, sorry for all the questions but this H/C stuff seems like you really need to get the right combination.
These are indeed new LS6 heads that we 5-axis CNC in house. The factory rocker assembly is re-used, however if you have high mileage or would like to upgrade rockers these can be purchased and installed at the same time. The "new and improved" Halltech is slightly more money than the Stinger, but you are welcome to upgrade this as well. We typically use the 1 3/4" headers with this package on a C5 and the 1 7/8" headers on the C6.
