10-30-2007, 02:04 PM
CF Senior Member
Burnin:
I have an '84 as well and it did the same thing to me several years ago. Just open the door, pull the hood release lever and hold. Take a pair of pliers and grab each cable(2) individually and pull down towards the doorsill. The hood should pop open no problem. This is a temporary fix; you will eventually need to replace the entire cable/level assembly(all one piece) to permanently eliminate the issue.
Brian A
90 ZR-1
12.09@118
01 Z06
not quite stock
