Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Great Lakes
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Great Lakes
Illinois | Indiana | Iowa | Michigan | Missouri | Minnesota | Ohio | Wisconsin
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-07-2006, 10:06 AM   #1
acrace
CF Senior Member
acrace's Avatar
Default SE MI C5 Fender Repair - Recommendations?
Okay, I must've gotten careless with my jack last year. While getting my C5 ready for this year I noticed a small crack on my right front fender, near the lower attachment point (behind the wheel opening). The crack hasn't reached the attachment point yet. Wondering if anyone out there has recommendations on how to fix this and/or where to get it done. I'm not good on bodywork. I'm thinking that the crack could be repaired with some reinforcement from the backside, therefore I don't need to get the fender refinished.
I live in Livingston County, by the way (Genoa Township). Will travel to have this done right!
__________________
Al Chan
2003 Z06
2009 Z06
acrace is offline   Reply With Quote
Old 04-07-2006, 08:56 PM   #2
yelloyello
CF Senior Member
CI 6-7, 9-10 Veteran
yelloyello's Avatar
Try Penningtons on Rochester Road in Troy. Just north of 15 mile road. I know they do work on Vettes. Or even the Vette Shop which I believe is in Eastpointe. Good luck and be careful next time!
yelloyello is offline   Reply With Quote
Old 04-08-2006, 12:16 AM   #3
hokievette03
CF Senior Member
St. Jude Donor '05-'06
hokievette03's Avatar
Send a message via AIM to hokievette03 Send a message via MSN to hokievette03 Send a message via Yahoo to hokievette03
If it is not in a visible location, as in on the underside lying on your back to see it, I would leave well enough alone, now if it is on the class A surface aka visible from a standing position...maybe some work is in order..
__________________
EMC 6-12-53 to 5-9-04
Hokievette03
2003 50th Anniversary Coupe LE- MN-6, Mods Granatelli Dual cone Intake, hood seal, aluminum gas pedal, heated driver seat, Silver Stars high and low, customized VT stainless exhaust plate, gold lettering in the rear fascia, Autobuffs silver logo decals for the steering wheel and door sills, Z06 Screens for the front, JVC 12 Disc MP3 Changer, Door seal strips, painted hoodliner logo, Goodyear GS-D3's
hokievette03 is offline   Reply With Quote
Old 04-09-2006, 04:17 PM   #4
diviniti
CF Senior Member
St. Jude Donor '05
diviniti's Avatar
Send a message via AIM to diviniti
I have almost the same type of issue, but I think mine is a little worse.
I plan on fixing it before I repaint the car, just waiting for the 70* weather to hit.
Heres a pic of mine, the way yours sounds, its not as bad as this. Stupid lowered car..
diviniti is offline   Reply With Quote
Old 04-10-2006, 10:03 AM   #5
acrace
CF Senior Member
acrace's Avatar
diviniti and others:
Thanks for the replies.
diviniti - if you don't mind, when you fix yours, let me know what you did and whether you did it yourself or what shop did it.
The crack isn't visible unless you're laying on your back and know exactly what you're looking for. I was thinking that some reinforcement on the backside would prevent the crack from lengthening.
Old 04-10-2006, 03:21 PM   #6
Gordy M
CF Senior Member
Al
Get the BMW rubber jacking pads and leave them in the slots, that way you do not have to try to jack up the car using the pads edge.
Look at my car or Don's at the next event.
Gordy M is offline   Reply With Quote
Old 04-10-2006, 04:30 PM   #7
acrace
CF Senior Member
acrace's Avatar
Gordy:
Thanks. I'll have to make sure that I look you up next time.
Old 04-10-2006, 08:57 PM   #8
hokievette03
CF Senior Member
Or just make your own pads with an eye bolt and two hockey pucks, I think they are like $2 each at play it again, yelloyello and I made a set of 4 in like 20 minutes 2 summers ago...
Old 04-11-2006, 03:16 PM   #9
diviniti
CF Senior Member
St. Jude Donor '05
diviniti's Avatar
I plan on fixing it myself and repainting the car myself.
In your case, you might be ok with applying some plastex compound to the crack, and then just for peace of mind, lay a few pieces of fiberglass matting over the crack for reinforcement. (On the back side for both the compound and matting)
Old 04-12-2006, 09:46 PM   #10
Gordy M
CF Senior Member
Al
Check with Danny Kellermeyer, he should know all the good painters, find out where he takes his race cars.
Reload this Page SE MI C5 Fender Repair - Recommendations?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
