Corvette Forum
Go Back   Corvette Forum > Upcoming Events and Regional Discussion > Great Lakes
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Great Lakes
Illinois | Indiana | Iowa | Michigan | Missouri | Minnesota | Ohio | Wisconsin
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-25-2006, 05:45 PM   #1
jjk2509
CF Senior Member
jjk2509's Avatar
Default St. Louis Emissions (Failed test)
I recently moved to St. Louis and had my 98 tested for emissions. I had my car tuned after new heads, cam and LG headers with hi-flow cats. The tuner turned off the oxygen sensor codes. I check my codes before the test and I had no emissions codes. I then cleared all codes.
The test with the OBD showed the follow as not ready:
Catalyst
Evaporative System
Oxygen Sensor
Oxygen Sensor Heater
EGR System - Not Supported
Readiness - Failed
The technician informed me that the car failed and told me the computer codes were cleared and or the car needed to be driven larger so the computer could generate new information for the test.
He told me to drive the car for a few days and come back to be tested.
Does anyone have any suggestions on what to do? The tuner turned off some codes. Will I have problems?
Thanks in advance for any help.
jjk2509 is offline   Reply With Quote
Old 02-25-2006, 05:58 PM   #2
Riks40th
CF Senior Member
Riks40th's Avatar
Location: St. Louis, Mo......... 1993 Torch Red w/White Interior...2006-07 Bloomington Gold 2005-ZR1/C4 Gathering, 2001-2010 Funfest
I can't help you on your problem, I'm sure someone will chime in soon. If your going to need a mechanic, Bill at Elco Chevy is the man on C5's.
I just wanted to welcome you to St. Louis. If your looking for a local club to check out, look into http://www.route66corvetteclub.com/, we have alot planned for the summer, so if your looking for something to do or people to meet then look us up.
Rik
http://photobucket.com/albums/y126/Riks40th/
Riks40th is offline   Reply With Quote
Old 02-25-2006, 06:22 PM   #3
yankee0304
CF Senior Member
St. Jude Donor '07
yankee0304's Avatar
Send a message via AIM to yankee0304
Catalyst
Evaporative System
Oxygen Sensor
Readiness - Failed
The guy at the test center is correct-you will need to drive your car for a longer period of time to get those readiness tests completed. The EGR shouldn't be a factor in this case-if it's not supported, they can't test it. I'm not exactly sure how much your tuner had to do or change in the computer's programming, but if there is an issue that is still there, you'll still get one, if not all, of the same codes that were present the last time the light was on. One note on the evaporative system, and I know this is very basic and I don't mean to insult your intelligence, but make sure the gas cap is tight-the best way to know that it's tight, with Ford being the only exception I know of, once you here three clicks while tightening, you know that the gas cap is tight. That's not the only issue that could cause an Evaporative emissions code, but it's the cheapest and easiest possible cause to fix.
In regards to the Oxygen Sensor and the Oxygen sensor heater circuit, I'd almost be willing to bet that they are for the same oxygen sensor, but since I don't have the exact codes in front of me, I cannot say for sure. In my own personal experience with GM's O2 sensor heater circuit codes (they are electrically heated-it takes too long for exhaust gasses to get hot enough to do this on their own, so the extra help gives them the ability to get into closed loop-the fuel efficient way of running), if one should be set, it most likely means that the particular sensor that gave off the code is shot and should be replaced. I haven't been wrong yet in replacing one with a code of this nature, but there's always room for a first, which is why I'd like to see the codes for the 02 sensors. There may be more to this picture than I am seeing, and I don't want to find myself going down the wrong path in trying to help you.
I'm going to take this one step further just for the sake of conversation, and no more. Should the dead oxygen sensor (not the one with the heater problem) be after a catalytic converter, that would be the most probable cause of the cat code.
With all of that said, I don't think I can be of much more help at the moment.
-Brendan
yankee0304 is offline   Reply With Quote
Old 02-25-2006, 08:21 PM   #4
lspalding
CF Senior Member
lspalding's Avatar
It's true that you have to drive the car in varying conditions so that the system can check everything and give a 'ready' response when checked. You can't clear the codes just before the test and pass. I had a random misfire code stored in my dd, which I cleared by disconnecting the battery. Drove the car to work for a week before the test and passed just fine. If you can't drive the car for a while without getting codes you are f**ked.
__________________
Len
'04 Yellow Auto 7k mi (mine)
'95 Purple 6Sp 12k mi (hers)
lspalding is offline   Reply With Quote
Old 02-26-2006, 08:29 AM   #5
VetteTech81
CF Senior Member
VetteTech81's Avatar
Send a message via AIM to VetteTech81
Catalyst
Evaporative System
Oxygen Sensor
Readiness - Failed
I'm not sure if you will have problems if he turned codes off..
I am guessing he turned off the Rear O2 Codes?
If there were no emissions codes why did you clear all codes?
When you clear codes.. you also clear out the monitors that the test looks for to pass emissions and you have to wait till they run and pass before you go back to the testing center...
Note on EGR as I'm sure most know this.. The system is not supported because 97-up vettes do not have an EGR valve..
BTW: I learned something interesting on some vehicles the rear O2's effect the fuel trim I was shocked to hear/learn this in one of my classes yesterday. I guess they do this to protect the cat if they see a rich condition to lean it out ect.. its crazy.. not all cars are like this but some are the instructor/technician conducting the class showed an experiment with a signal generator in place of the rear O2 showed the fuel trim and pattern for the up stream O2 produced a lean condition on the REAR O2 with the signal generator and watched the UPSTREAM O2 show the exhaust was going rich. There is a percentage that the rear O2 does effect the fuel trims.. but again this is not on all cars but on many newer cars.. I wonder what happens when people start running hi flow cats, test pipes, and O2 sims on the rear of these cars..
Anyway there is only one way to find out if YOU are going to have an issue with passing.. DON'T clear the codes if non are set.. drive it.. highway local put some miles on it.. maybe have another non emssions tech like a local shop plug it and check to see if the monitors have ran and passed... I think here in IL you can have 2 monitors that have not ran and passed not 100% on this at the moment..
GOOD LUCK...
-=Rick
__________________
ASE Certified Master Technician & Corvette Specialist
http://www.facebook.com/VetteTech81
Mine: 1995 Admiral Blue LT1/4
Hers: 2002 Electron Blue Coupe
VetteTech81 is offline   Reply With Quote
Old 02-26-2006, 11:11 AM   #6
jjk2509
CF Senior Member
jjk2509's Avatar
I checked my codes to see if I had any emission problems, I did not.
I then cleared the codes I had without knowing this would mess up the test.
I guess you learn something new every day.
I will get retested on Monday.
Thanks for all of the help.
Old 02-26-2006, 07:05 PM   #7
yankee0304
CF Senior Member
St. Jude Donor '07
yankee0304's Avatar
Quote:
Rick,
I've heard the same info about our tests here, but for some reason I thought it was three, but I believe that you have the correct number.
Old 02-26-2006, 07:05 PM   #8
yankee0304
CF Senior Member
St. Jude Donor '07
yankee0304's Avatar
Let us know what happens.
Old 02-28-2006, 02:55 AM   #9
GTENIT
CF Senior Member
GTENIT's Avatar
I Thought All They Did Was A Sniffer Test. Glad I Dont Live In St Louis. Would Have To Get A Po Box Out Of Town
__________________
72 convertible 434 small block
700-r4 3:70 rears
98 AMATHESIS (PURPLE) CONVERTIBLE 6SPEED
GTENIT is offline   Reply With Quote
Old 02-28-2006, 10:41 AM   #10
plaster
CF Senior Member
plaster's Avatar
Quote:
They don't do a sniffer test, unless they do not have enough info from the scan or your light is on.
No way my car can pass at the pipes, but I kept throwing codes. HAd to get the thing retuned (pretty modified), and there was still a code that woul dcome on. Even though they tested my cap, I got a new one and now the light rarely comes on.
DO NOT go to O'Fallon station - apparently have never lifted a Corvette hood and asked me where my air pump was - I said 'shouldn't you know that? I just bought the car last week!'
plaster is offline   Reply With Quote
Reload this Page St. Louis Emissions (Failed test)
Tags
c6, car, corvette, egr, emissions, failed, gateway, hood, o2, sensor, set, stl, system, testing, unsupported
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
You missed your chance to buy a legendary 1967 L-88 racer...... 67HEAVEN C3 Tech/Performance 9 10-23-2002 05:44 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
