Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-24-2003, 05:39 PM   #1
mayberg
CF Senior Member
mayberg's Avatar
Default How do I rivet? - not pop rivets
Experts of varying degrees:
I got the front chin spoiler extension add-on thingy from the good doctor for Christmas for my 1974, and I got the correct black rivets to attach it to the car. I was happy as a clam thinking I would use the pop rivet gun that the guy that owned my house before I did left for me (free tools!) to attach this to the car.
These rivets aren't pop rivets. They're just plain old rivets - they don't have the little pin thingy going back through the head.
What do I do? Is there some other kind of rivet tool for these kind of rivets?
Thanks, GM
mayberg is offline   Reply With Quote
Old 01-24-2003, 06:00 PM   #2
Chuck Gongloff
CF Senior Member
Support Corvetteforum!
Chuck Gongloff's Avatar
Default Re: How do I rivet? - not pop rivets (mayberg)
Hello Guy. I can offer a LITTLE insight. I've placed "correct" aluminum rivets through fiberglass doing any number of projects. Can't speak about this special black rivet, but you need a "buck"....or an anvil type gizmo to hold the head flat against the surface. You can actually use a hammer head for this. You then need another hammer to "bop" the other end to peen over the rivet. It can be a real PIA, especially when you don't have a lot of room to swing a hammer.
I don't know a better way, as I don't own a special "real" rivet setup. Hope this helps. Chuck
Chuck Gongloff is offline   Reply With Quote
Old 01-24-2003, 06:26 PM   #3
M.Y.Freak
CF Senior Member
As far as what to use to peen over the skinny end of the rivet, I've taken a king pin & drilled the end just deep enough to smash the rivet to resemble a factory job. Sometimes it comes out pretty good, sometimes not so good. Practice, Practice, Practice!
Some of the major vendors(LICS for one) sell various sized tools for different rivet sizes.
M.Y.Freak is offline   Reply With Quote
Old 01-24-2003, 08:01 PM   #4
Larry B.
CF Senior Member
Larry B.'s Avatar
Default Re: How do I rivet? - not pop rivets (Chuck Gongloff)
there is a pneumatic tool called a rivet squeezer that works very well if the rivets are reasonable close to an edge. Either way you need a special tool that most of us don't have. Some of the aviation mechs may have one or both kinds.
:smash:
[Modified by silvervetteman, 7:02 PM 1/24/2003]
Larry B. is offline   Reply With Quote
Old 01-25-2003, 01:16 AM   #5
Mac
CF Senior Member
Mac's Avatar
Have I got a thread for you, mayberg!
http://forums.corvetteforum.com/zerothread?id=315457
I'm looking at getting one of the spoilers. Let me know how it goes!! :)
Mac is offline   Reply With Quote
Old 01-25-2003, 07:29 AM   #6
Larry B.
CF Senior Member
Larry B.'s Avatar
When you choose a tool... Be aware that an air hammer/(muffler chisel) is NOT a rivet gun. The rivet guns have a very controlable trigger and are designed for installing rivets. You can do the job (or a lot of damage) with a cheap air hammer like the poster said by turning the air pressure down.. Practice on a few scrap pieces until you get a feel for it.
[Modified by silvervetteman, 8:33 PM 1/26/2003]
Old 01-25-2003, 11:32 AM   #7
Red69
CF Senior Member
Red69's Avatar
Send a message via AIM to Red69
(Assuming you are refering to the OEM style rivites) one of the key points to get "good looking" results when using this type of rivit is the length of the shank.... If it sticks out too far, you'll have too much material to peen over... too short, not enough... Dr Rebuild's web site talks alittle about installing this type reivit... The gripping power is in the expansion of the shaft... not the peened head... so, the shaft length is important. They can be easly cut with dykes! ... I usually leave about .25" sticking out... and use a small sledg on the back side as my anval and a small ball-peen for "pounding" the shank down...
Good advice is practice, practice, practice....!
John
Red69 is offline   Reply With Quote
Old 01-26-2003, 09:32 AM   #8
Larry B.
CF Senior Member
Larry B.'s Avatar
Default Re: How do I rivet? - not pop rivets (Red69)
The end should stick out 1 1/2 times the diameter. The rivet should not be sloppy in the hole or it will bend over and look terrible.
Old 01-26-2003, 01:48 PM   #9
JohnZ
CF Senior Member
Default Re: How do I rivet? - not pop rivets (silvervetteman)
Here's what I use - an Ingersoll-Rand air gun, dedicated regulator just for this application (set at 15-20 psi), and a concave-face 3/16" rivet-setting tool on a .401" shank to fit the gun. Aircraft Tool Supply Co. ( http://www.aircraft-tool.com ) has a terrific selection of 3/16" rivet-setting tools in many lengths and shank shapes. Just trim the (soft) rivet (I get mine from Dr. Rebuild) to correct length, back up the large end with an old hammer head, and the rivet-setter peens it in a flash with a nice rounded end.
:steering:
JohnZ is offline   Reply With Quote
Old 01-26-2003, 09:29 PM   #10
'65 Fuelie
CF Senior Member
'65 Fuelie's Avatar
Default Re: How do I rivet? - not pop rivets (JohnZ)
I have tried every conceivable method of peening the rivets and John's method is the ONLY way to do it right.
'65 Fuelie is offline   Reply With Quote
Reload this Page How do I rivet? - not pop rivets
Tags
corvette, rivet, smash
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Antenna Mast Replacement scorp508 C4 Tech/Performance 15 07-11-2005 04:06 PM
What I did this weekend - #4 body mount reinforcement [PICS] NHvette C3 Tech/Performance 13 07-29-2004 08:17 PM
rear disc removal?? how? LATNC3 C3 Tech/Performance 18 04-27-2002 11:54 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
