I am looking for a Rochester Quadrajet Carb No. 7040207, dated before 2-20-70, to replace the incorrect one currently on my car. If I go back six months into 1969, the number would have then been 7029207. Would this pass an NCRS judge as long as it is not over six months prior to my build date?
You might want to check with Juliet. She has a somewhat early 70, and I believe she learned that Carter built some Qjets for the 70s. They might be easier to find than the right Rochester. MJ
the original equiptment q jets built by carter still use the GM numbers except the replacemant ones sold thru the auto parts which used carter numbers. :chevy
