Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-12-2003, 09:57 AM   #1
Larry B.
CF Senior Member
Larry B.'s Avatar
Default Radiator ID tag question.
My radiator is out.. What a job :cuss :cuss ... The little snap on tag reads MJ9 ...Anyone know what it means?
Larry B. is offline   Reply With Quote
Old 01-12-2003, 01:20 PM   #2
Chuck Gongloff
CF Senior Member
Support Corvetteforum!
Chuck Gongloff's Avatar
Default Re: Radiator ID tag question. (silvervetteman)
Don't remember exactly, but MJ is a code. Look in the parts book. Where the radiators are listed, the listing is followed by the code. Mine was/is M something. The code tells you the original application....427 with manual trans, etc. Not sure about the "9" Chuck
[Modified by Chuck Gongloff, 12:21 PM 1/12/2003]
Chuck Gongloff is offline   Reply With Quote
Old 01-12-2003, 02:38 PM   #3
SWCDuke
CF Senior Member
It's the radiator production code that is determined by the RPO combination of your car, and it will be printed on the broadcast (build) sheet.
Production codes are the same format as RPO order codes - three digit alpha-numeric sequence. When the order was keyed into the plant computer, it generated the broadcast sheets with all the proper production codes, which was then used by plant personel to install the proper parts on your car for its combination of ordered RPOs.
If you look closely at the radiator tag, it might also have a GM long number, and there may be some other data, which is probably lot/date code and vendor code.
If you send your radiator out to a shop for checkout or repair, remove the radiator tag and save it for reinstallation when you get it back. Radiator shops just throw them away. If it can be seen on the car, it is probably subject to NCRC judging.
Duke
SWCDuke is offline   Reply With Quote
Old 01-12-2003, 04:46 PM   #4
Larry B.
CF Senior Member
Larry B.'s Avatar
Default Re: Radiator ID tag question. (SWCDuke)
ok... I cleaned the tag up and sure enough there is a part number. 3018571. I have an AIM but Murphy's law prevails and the radiator number is off of the copied page at the very top. Can anyone varify what I have?
Reload this Page Radiator ID tag question.
Tags
3018571, gm, id, radiator, tags
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Info About My '69 L46 from NCRS Manual ... TedH C3 Tech/Performance 21 01-25-2005 03:29 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
