Thanks Wayne and Jerry, yes Holley rebuilt the carb. I called the Tech Line at their facility in Springfield, Tennessee and the tech on the line said Holley uses mineral spirts to flow test their rebuilds. He said my problem was probably the float levels and to remove the fuel bowls, flip them upside down and check the adjustment. The top tangent line of the float should be parallel to the bowl, and when I checked them, they were.
As he advised, I bent the tabs on the floats down about 1/8", so that they closed the needle valve earlier and would lower the fuel level. It didn't help.
I've had this carb apart twice now, checked everything I could, tightened every screw, blew out every orifrice and have tried many different adjustments while it was on the engine running, and I am getting nowhere fast.
I think I'm going to give it to Jerry MacNeish at
http://www.z28camaro.com/ and let him look at it. John Z and Jerry Clark swear by him and his shop is just down the road from me. Anyone else heard of him?
So now that means I don't have to fool around with this carb today and can wash my new Nuclear Banana for the first time! :thumbs:
