Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-04-2002, 10:38 AM   #1
joe58
CF Senior Member
Default looking for help with Borg Warner trans ID 1959?
I have a BW T10 that I am trying to identify. It has WD2792 stamped on cover side of case which I decode as Warner June 27 1959 2nd shift. The cover is cast iron and has 13-04-097-901 cast in. The case is aluminum and has 1304065903 WG DIV FPC3 cast in. The tail is aluminum and has 3 tapped holes for shifter which I read indicates early units?.
My research so far shows the 1959 should have a cast iron case. Is it a Corvette trans or Impala or other GM application? thanks
here is a picture
joe58 is offline   Reply With Quote
Old 11-04-2002, 01:58 PM   #2
JohnZ
CF Senior Member
Support Corvetteforum!
Default Re: looking for help with Borg Warner trans ID 1959? (joe58)
It's an April 27, 1979 Borg-Warner Super T-10; tailhousing should have casting # 13.04.066.905, and rear bearing retainer should be T89C-6A. The aluminum main case indicates it's an OEM transmission - the aftermarket super T-10's of that era had cast iron main cases.
JohnZ is offline   Reply With Quote
Old 11-04-2002, 02:06 PM   #3
joe58
CF Senior Member
Default Re: looking for help with Borg Warner trans ID 1959? (JohnZ)
thanks John
Reload this Page looking for help with Borg Warner trans ID 1959?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
