Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-01-2002, 06:15 PM   #1
Viet Nam Vett
Everthing ..All The Time
St. Jude Donor '04-'05-'06-'07-'08-'09-'10
Support Corvetteforum!
Viet Nam Vett's Avatar
Default Numbers,Numbers, Numbers!!!! Which one is Correct??? Maybe Zora Knows!
My Freind is looking for the correct BB 1966 Bell Housing. I posted WTB on the C1 C2 Parts Forum. The Number My Freind has came from the NCRS manual. It is a ..3872444 for BB Bell housing. DaBo Replied that he has one but different numbers. See Post Below... Which One Is It???
From Parts Post.
The following reply was posted by DaBo:
My records...(GM microfiche) indicate that you should need a # 3899621 for
1966-1981 350,427,454.
1966 427 Special High Performance would be a # 3858403.
Maybe some others can agree or disagree on this.
I am not sure what your number is. (3872444)
David
Confusing :confused: :confused: :confused:
Viet Nam Vett is offline   Reply With Quote
Old 11-01-2002, 07:00 PM   #2
JmpnJckFlsh
CF Senior Member
Default Re: Numbers,Numbers, Numbers!!!! Which one is Correct??? Maybe Zora Knows! (Viet Nam Vett)
From the NCRS manual...? If it is the 65-66 TIM&JG (judging manual), then that is the part number that originally came on the cars, but I would make sure that I was interpreting the manual correctly.
It is possible that both numbers are functionally correct because it was not unusual for GM to re-issue a replacement part with a new part number. My parts book, which includes replacement parts for all 53-72 Corvettes as of 1972 shows the same thing as DaBos microfiche: bell housing for 66-72 Corvette (350, 427, 454) is part number 3899621; 66 Corvette with Sp. H. Per and L88s is 3858403
The 3899621 bell housing was in production cars by at least 1970. If the later design bell housing also worked on any earlier power trains, then the current production part would probably have superceded the earlier part number to reduce replacement parts inventory.
If this is true, then it all comes down to your friend's preference: original part number or replacement part number? My opinion is that the bell housing part number probably isn't judged since it may not be visible under the car, but if the bell housing can be identified as non-original from any visible portion, he could get judging deducts. He should talk to a midyear chassis judge before deciding which bell housing he needs. I would probably try to find the original part number if I could.
JmpnJckFlsh is offline   Reply With Quote
Old 11-01-2002, 07:54 PM   #3
Viet Nam Vett
Default Re: Numbers,Numbers, Numbers!!!! Which one is Correct??? Maybe Zora Knows! (Chuck Sangerhausen)
Thanks Chuck,
I'll email your reply to him.............. :cheers:
[Modified by Viet Nam Vett, 12:42 AM 11/2/2002]
Old 11-01-2002, 08:19 PM   #4
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
my list shows that the 3899621 is for a 11" clutch and the 3858403 is used with a 10 1/2" clutch like the L-88 :chevy
clem zahrobsky is offline   Reply With Quote
Old 11-01-2002, 09:41 PM   #5
Viet Nam Vett
Default Re: Numbers,Numbers, Numbers!!!! Which one is Correct??? Maybe Zora Knows! (clem zahrobsky)
Clem, Thanks I sent your post on ............... :cheers:
Old 11-02-2002, 01:12 AM   #6
Pillman7
CF Senior Member
Pillman7's Avatar
According to Noland Adam's Corvette Technical and Restoration guide for 1963-67 Corvettes in which he publishes the results of some surveys he did while researching information for his book, the correct bellhousing for a 1966 427 L36 and L72 engines was 3872444. The base 300hp and the 350 hp L79 engine used 3858403. The 3899621 bellhousing was for a L89 1967 427 with the aluminum cylinder heads. I hope this sheds some light on your problem.
Pillman7 is offline   Reply With Quote
Old 11-02-2002, 02:31 PM   #7
JohnZ
CF Senior Member
Default Re: Numbers,Numbers, Numbers!!!! Which one is Correct??? Maybe Zora Knows! (Pillman7)
#3872444 was used on early '66 BB's, #3899621 on later '66 thru '74 BB's; they are absolutely identical in every respect except for the casting number (which is not judged, except in "Bowtie" judging). For Flight judging, either one is acceptable.
JohnZ is offline   Reply With Quote
Reload this Page Numbers,Numbers, Numbers!!!! Which one is Correct??? Maybe Zora Knows!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
