Quote:
Have a VIN of # 30837S111042 and
Motor Serial #3782870.
What does this tell me ??
OK, here's the easy part: the car is a 63 Corvette convertible, but if you own the car, you probably know that.
[Edit: Sorry, Bill, the VIN is actually for a 63 Corvette coupe. My mistake.]
The hard part: The "motor serial number" you have posted doesn't make sense in the context of a 63 Corvette. You may be reading something as a serial number that doesn't have anything to do with the engine ID.
The pad in front of the right head should have a stamp that starts with an "F", followed by 3 or 4 digits representing the date, then a two letter suffix code which identifies the engine horsepower and transmission. The pad should also have a second stamp with some form of the car VIN number, or "111042".
If this "motor serial number" really is stamped on the front pad, then something is awry...post the block, intake manifold, and head casting numbers if you can, and maybe we can figure the engine out that way.
[Modified by Chuck Sangerhausen, 7:25 PM 10/29/2002]
