Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-27-2002, 10:41 AM   #1
67HEAVEN
CF Senior Member
67HEAVEN's Avatar
Default Son of Maryland Spring Compressor........
The Ontario Bearing Race Press.... :lol:
If you don't have easy access to a hydraulic press......and.......you don't have the correct diameter drift to go along with it.......here's a solution for pressing in the inner and outer bearing races for the rear spindle.
Both inner and outer races are actually "recessed" below the face of the spindle, meaning that if you simply use this homemade tool as a press, the races will not be limited against (or reach) their seats in the spindle. The press will limit against the spindle face before the race is all the way in.
What to do?
Easy........you did keep the old races that you previously pounded out of the spindle, right? (You always keep "all" the old parts at least until the job is complete, right?) :D
Simply set the old race on top of the new race to add the "correct diameter" extra press depth required to push that new race fully into the spindle. Squeeze the lower nut in the vise and turn down the upper nut to activate your homemade "press".
The old race does tend to get stuck in there on top of the new race, but you simply turn the spindle over and lightly tap the "extra" race out using a screwdriver. Job done. :cheers:
One final note. It is crucial to start pressing with the races sitting flat. You don't want to press them in on an angle or "crooked". Eyeball them first.
67HEAVEN is offline   Reply With Quote
Reload this Page Son of Maryland Spring Compressor........
Tags
compressor, maryland, spring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
The Maryland *REAR* Spring Compressor.... Juliet Factory Correct Resto 9 06-24-2002 02:37 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
