Automatic
61 corvettes came with a cast iron air cooled powerglide, but it would be better/easier IMO if you just find a long shaft aluminum powerglide with mounting holes cast into the tailhousing. Or you could fabricate a bracket to hold the shifter to the tailshaft also.
Go to the C1 C2 section of the forum, lot more active than this section
Received 1,469 Likes
Cruise-In II Veteran
