64 rear body mount access plate finish
I used the search function, but I couldn't find an answer to what the finish on the rear body mount access plate should be. I assume it wasn't present during the undercoat and blackout procedure, but my original was mostly rust, so I have no idea what the plate or the mounting screws should look like when installed.
Received 1,857 Likes
Semi-flat black is correct - they were dip-primed black prior to installation. There should be NO undercoat on them - they were installed after Body Drop.
