Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-29-2009, 02:33 PM   #1
roger55
CF Senior Member
roger55's Avatar
Default Courtesy Light Bulb Socket
On my '69, the snap-in bulb socket for the LH (driver side) under dash courtesy light is missing. The bracket that holds the socket has a 3/4 inch hole and I can't find a replacement socket for this anywhere. I know that the socket has to be a 2 wire socket and that the socket can't ground to the bracket. So, I assume it's a plastic socket. I can find a 2 wire plastic socket that is for a 5/8" hole but not for a 3/4" hole.
Anybody know where I can get one? Help will be appreciated.
roger55 is offline   Reply With Quote
Old 09-29-2009, 09:25 PM   #2
gbvette62
CF Senior Member
gbvette62's Avatar
I don't know why so many of those sockets are missing from 68 up Corvettes. I've cut off and sold every one I had on old junk harnesses. The big wiring companies (Lectric Limited, M & H, etc.) won't sell sockets, they want to sell you a complete harness! I remember that Eagle Wiring use to sell those sockets separate, when they where in Tenn. The company was sold about 2 years ago and moved to Ohio. With the change in ownership, I don't know if they will still sell those sockets separately, but they could be worth a try. I don't have their number at home here, but a quick search of the net would probably turn it up.
gbvette62 is offline   Reply With Quote
Old 12-07-2009, 07:24 PM   #3
DZRick
CF Senior Member
DZRick's Avatar
I thought this was the correct lamp bracket for the drivers side.
Here it is in place.
DZRick is offline   Reply With Quote
Old 12-07-2009, 08:25 PM   #4
roger55
CF Senior Member
roger55's Avatar
Yes, that is the same bracket I have. But, it's the bulb socket I can't find.
Btw, I know one of the cables is the trip odometer reset, but what is the other cable for? I don't have anything in that other hole on mine.
Old 12-07-2009, 08:31 PM   #5
DZRick
CF Senior Member
DZRick's Avatar
Damn it Roger, my reading skills are getting worse every day.
I may have a socket for you, give me a couple days and I'll see if I do.
The 2nd cable is to set the speed-warning.
Old 12-07-2009, 09:50 PM   #6
roger55
CF Senior Member
roger55's Avatar
That would be cool!
Oh, I guess that speed-warning on the speedo must be an option. Mine doesn't have it.
Old 12-07-2009, 11:41 PM   #7
DZRick
CF Senior Member
DZRick's Avatar
That would be cool!
The speed warning was an option not many ordered it and even with stock exhaust it was pretty useless. With side pipes totally useless!
Old 12-08-2009, 11:30 AM   #8
DZRick
CF Senior Member
DZRick's Avatar
Sorry Roger, I know I didn't cut the sockets out of this harness but they are gone.
Old 12-08-2009, 12:25 PM   #9
roger55
CF Senior Member
roger55's Avatar
Thanks for looking!
Old 12-08-2009, 02:41 PM   #10
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
I took my bracket with me to the generic auto parts joint and searched through the open stock until I found a replacement. It isn't GM, but it works and does not show once it's installed in the bracket.
Easy Mike is offline   Reply With Quote
Old 12-08-2009, 03:35 PM   #11
roger55
CF Senior Member
roger55's Avatar
Quote:
I searched in several auto parts stores around here and haven't found anything that will work.
I don't suppose you save your receipt that might have a part#?
Reload this Page Courtesy Light Bulb Socket
Tags
1996, 58, bulb, c3, corvette, courtesy, dash, gm, hole, interior, lamp, light, mini, replacement, socket, sockets
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Exciting story w/puzzle at the end... foundvettelifeisgood C3 Tech/Performance 11 02-23-2005 08:37 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
