Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-12-2009, 04:22 PM   #1
kaiserbud
CF Senior Member
kaiserbud's Avatar
Default Restoring Ralley Wheels
I have a set of Ralley (sp?) Wheels and would like to clean them up. I do not have to go factory correct, but I hear its Argent Silver color - but is it black on the back or more Argent? Where do you get the paint or similiar colr. What are suggested steps. What type of coating is appropriate for the inside of the rim?
I was initially going to sandblast and have powder coated a close color. I am open to your thoughts/suggestions?
kaiserbud is offline   Reply With Quote
Old 07-12-2009, 06:03 PM   #2
JohnZ
CF Senior Member
Support Corvetteforum!
The factory dip-primed them semi-gloss black, then sprayed the face with argent silver wheel enamel; the back side of the wheel remained semi-gloss black.
JohnZ is offline   Reply With Quote
Old 01-19-2010, 06:09 AM   #3
Bill W
CF Senior Member
Bill W's Avatar
I recomend the sand blasting part whatever color you decide to paint them. When I was restoring my 70, the shop estimated that there were 14 coats of argent silver on the wheels. Apparently, the previous owners just sprayed a coat on top each time the wheels would get to looking ratty.
Bill W is offline   Reply With Quote
Old 01-19-2010, 11:21 AM   #4
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
Argent silver:
Ditzler/PPG DDL 8586
DuPont 9692L
Easy Mike is offline   Reply With Quote
Old 02-02-2010, 02:07 PM   #5
Ravine Speed
CF Senior Member
Ravine Speed's Avatar
I just "restored" two rallys. These posts are accurate, but according to the NCRS guide, in '68 and '69 the Argent had a "greenish tint" to the paint. I don't know how close you need to get to original, but the paint I used doesn't have any greenish tint.
Additionally, the cleaning up of these wheels is tough; the seam where the inner is welded to the cylinder (on the outside, silver side) is an absolute bi7ch to get clean. I used dental tools and sewing needles to clean out the seam (a lot of gunk resides there) and although I got it completely clean, the paint still collected in that "valley" and looks a little crusty. I think there may have been some type of sealant used in combination with the welds that you just really can't get out of that tiny little seam. You may be able to avoid the "pooling" of the paint if you stand them up on their edge to paint them.
The good news is that from the factory, these babies looked pretty bad. They were hung on a hook through the valve hole to paint. The NCRS guide goes on to read that the paint was applied poorly and it is not unusual to have runs and drips.
Ravine Speed is offline   Reply With Quote
Old 02-02-2010, 10:08 PM   #6
oldsarge
CF Senior Member
oldsarge's Avatar
Eastwood supplies
oldsarge is offline   Reply With Quote
Old 02-08-2010, 04:46 PM   #7
gq82
CF Senior Member
gq82's Avatar
PPG formula #8568
gq82 is offline   Reply With Quote
Old 02-18-2010, 04:35 AM   #8
La Orange
CF Senior Member
La Orange's Avatar
Hi
The last set i did
1 Remove Tire, Valve stem, and wheel weights
2 Blast wheel to clean metal both sides
3 prime wheel with Black etching primer
4 paint front side with argent silver correct for your year
* note only overspray of silver on back side of wheel do not paint silver
on back
If not NCRS clear coat for more protection
__________________
La Orange
72 Ontario Orange roadster
05 Daytona Sunset Orange Convertible
La Orange is offline   Reply With Quote
Old 04-24-2010, 02:04 AM   #9
Rudy's Stingray
CF Senior Member
Rudy's Stingray's Avatar
This is so true.
After I sand blasted my wheels, I blew them off with compressed air,
in every nook and cranny and still, sand showed up when I painted
them. I didn't touch them while I applied several light coats of
Eastwood Argent Silver; the sand found it's way out.
Like the previous poster stated, the factory paint job, the wheels and
even the bodies was not the best. If your patient and have attention to
detail, your paint job will be 100% better than what Chevrolet did.
Rudy
__________________
Rudy's 1970 Chevrolet Corvette L46 350/350 Hp
4-speed 2 top convertible
Rudy's Stingray is offline   Reply With Quote
Old 08-04-2010, 05:30 PM   #10
00Nassau
CF Senior Member
St. Jude Donor '11
00Nassau's Avatar
None of the Argent Silver paints from the normal suppliers will match the original 69 wheel color. I bought paint from four different sources and finally gave up. I have sold the car, and the new owner found an original wheel and had paint mixed to match it.
00Nassau is offline   Reply With Quote
Reload this Page Restoring Ralley Wheels
Tags
argent, buy, color, correct, corvette, eastwood, gm, google, paint, ralley, restoring, rims, semigloss, silver, wheel, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Matching Numbers - Which #'s Actually Match KALAWAY C3 Tech/Performance 28 03-09-2005 11:10 PM
Am. Racing Mag Wheel Pintobay C1 & C2 Corvettes 23 04-15-2003 12:06 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
