Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-14-2009, 01:59 AM   #1
PINKFLOYD_
Junior Member
Default Putting on a New front bumper help
Hi All, Im new here. In return for all the greatfull things my father has given me, I plan to buy a new bumper for his 74'. His finances currently dont allow him to put purchase one. I remember a while back of him saying he would need braces or bolts as they usually break?
Thank-you for the help, I really appreciate it.
-Paul
PINKFLOYD_ is offline   Reply With Quote
Old 05-15-2009, 01:49 AM   #2
gbvette62
CF Senior Member
gbvette62's Avatar
74 to 82 urethane bumpers were held on using retainer strips. If memory serves me correctly, the 73-74 from bumper used 4 retainers, 1 curved one on each end and 2 staight ones across the top. These retainers were just stamped steel with threaded studs welded on every couple inches. With age and exposure to the elements, the nuts on the studs rust and bond to the studs. When you go to unbolt the bumpers, half the studs snap off.
If your replacing the bumper with another urethane one, you'll need to use retainer strips. The retainers are repro-ed, the 4 pieces needed run about $100.00. If your going with fiberglass bumpers, you can buy the "T" bolt set of retainers on the market (about $29.00 for the set, I think), or just use nuts bolts and washers. Either will work fine with the fiberglass bumpers, but with urethane ones you must use retainers to keep the urethane tight against the body and prevent waviness.
gbvette62 is online now   Reply With Quote
Old 05-15-2009, 11:14 AM   #3
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
Purchase the 1974 Corvette Assembly Instruction Manual (AIM). The AIM shows how the cars were assembled on the line, lists illustrations, original part numbers, notes on assembly, torques, etc.
The AIM will show how the original bumper cover was installed at St. Louis.
Easy Mike is offline   Reply With Quote
Old 05-15-2009, 10:55 PM   #4
Willcox Corvette
Premium Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12
Willcox Corvette's Avatar
Send a message via MSN to Willcox Corvette
Posted on your other thread and GB is correct! Only use the individual retainers on fiberglass or flexy glass covers. Not on Urethane.
Willcox
Willcox Corvette is offline   Reply With Quote
Reload this Page Putting on a New front bumper help
Tags
assembly, bumper, c5, corvette, front
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 03:23 PM
C5 Front Bumper Durability - Opinions??? QuicksilverC5 C5 General 9 04-24-2005 11:14 AM
Tested the Big Mouth Air Dam! Great results. . . PaceThis C5 General 56 08-08-2004 11:04 AM
Help 67 on my mind! polyrocks C1 & C2 Corvettes 41 07-02-2002 11:51 AM
What are the Disadvantages of Getting a 91-2 Z over 94-5? LowFlight C4 ZR-1 Discussion 13 02-19-2002 10:23 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
