Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-10-2009, 05:14 PM   #1
tshirttom
CF Senior Member
Default Torque Specification question
The torque specifications in the owners manual..Are they meant for dry or lightly oiled fasteners? I usually hate putting a dry fastener on and also always use never-seize or some lube. I am sure this affects the torque valves, but in a quantifiable manner? . Any mechanic or engineer want to weigh in on this please?
tshirttom is offline   Reply With Quote
Old 02-10-2009, 05:26 PM   #2
GDaina
CF Senior Member
Support Corvetteforum!
GDaina's Avatar
Send a message via Yahoo to GDaina
I believe those are dry specs
GDaina is offline   Reply With Quote
Old 03-05-2009, 03:43 PM   #3
tshirttom
CF Senior Member
Default Torque Specs
Will using a long extension on the torque wrench affect the result at all?
Old 03-05-2009, 08:14 PM   #4
JohnZ
CF Senior Member
Quote:
Nope - only if you use a crowfoot wrench/socket on the end whose center is offset from the axis of the extension.
JohnZ is offline   Reply With Quote
Reload this Page Torque Specification question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 PARTS & TECH NEWS 09-02-05 NEW INFORMATION CorvettePartsBob Ken's Newsletters 12 12-04-2005 01:59 PM
Proper lube for T-10? swissie C1 & C2 Corvettes 14 01-24-2005 02:52 PM
Broken Piston and damaged Head :( tshort C3 Tech/Performance 40 10-06-2004 12:44 AM
Valve Lash Question chucks88 C4 Tech/Performance 18 11-20-2003 03:04 PM
Rear Suspension...AGAIN! This time not as bad though...Tech question... BatMobile C5 Tech 15 10-27-2002 11:56 AM
LT-1 cam question. gdh Engine Mods 15 10-12-2002 02:32 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
