Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Delco Distributor identification
Old 02-10-2009, 11:07 AM
Bob Onit
Bob Onit's Avatar
Default Delco Distributor identification
Hi All, I have a delco remy tach drive dist here with a red band that reads 1112021 DELCO REMY 2H 2
Can anybody tell me what these numbers mean?
Thanks!
Bob
Old 02-10-2009, 12:39 PM
gbvette62
gbvette62's Avatar
Received 2,028 Likes on 1,314 Posts
1112021 is late production 1970 for a 350/350. 2H 2 I believe is dating. I'm having a senior moment, but I think it works out as follows: "2" second day of the month, "H" August, "2" second shift.
Old 02-10-2009, 12:58 PM
Bob Onit
Bob Onit's Avatar
Thank you very much!
Old 02-10-2009, 03:25 PM
Bob Onit
Bob Onit's Avatar
Can anybody please explain what the raised casting numbers at the top of the casings represent?
I have two different units.
One says 190 and the other says 691
Thanks.
Old 02-10-2009, 04:20 PM
Vetteaddiction
Vetteaddiction's Avatar
Bob,
I believe you have a replacement distributor. The distributor is for a 1970 350/350, but the id band says 2 August, 1972. It's yr/mo/day. Of course, you could have the wrong id band, they're easy to remove and replace.
The casting number on distributors has never been a source of any meaningful info. Still a mystery.
Chris
Old 02-10-2009, 04:28 PM
Bob Onit
Bob Onit's Avatar
Originally Posted by Vetteaddiction
Bob,
Chris
Hmm.... Now I'm a little more confused.
Thanks very much (I think)
Anybody else want to confirm?
Thanks guys!
Old 02-11-2009, 09:12 AM
Bob Onit
Bob Onit's Avatar
Bob,
Chris
Chris, would a "replacement" unit still be considered "correct" to a person that is looking for a proper year distributor?
Heres the issue I'm having.
I bought a spare tach drive dist for my '73.
I bought it from a local guy that was parting out a '70 350/350.
I sent the dist to Lars and he rebuilt it completely.
New shaft, bushings, drive gear, coupling, vacuum control, ect: then Lars also set the advance curve on his SUN machine.
I installed it on my beefed up L-48, it worked flawlessly.
Shortly after this I bought a ZZ-4 and went with an HEI tach drive.
Bottom line is that I have a lot of money into this distributor and I want to sell it but I don't want to advertise it as a 1970 unless I'm positive that it is indeed from a 1970.
Can anybody tell me if there is an accurate procedure to verify the year of this distributor?
I have attached a couple of pictures so you can see the unit and the numbers.
Thanks for your help so far guys. I appreciate it.
Bob.
Old 02-11-2009, 11:09 AM
Vetteaddiction
Bob,
There are some numbers under your cam and weight plate (under the plate that holds your springs and weights). Should be CCW xxx . Plates have different slot lengths that allow different amounts of centrifigal advance. Some people have a cross reference to actual part numbers that can help narrow down the application.
The other way is to look at the part number on the vacuum can, but I bet Lars swapped that out. Did he set it up for your L48? If so, it won't be right for a 70 350/350, different specs.
Chris
Old 02-11-2009, 11:45 AM
Bob Onit
Bob Onit's Avatar
Bob,
Chris
Chris, Lars did change out the can, he uses one type and one type only (B28?) or something like that.
I have no idea how he set the curve, he did it on his SUN machine.
The L-48 was probably close to 280 hp gross.
I didn't consider that aspect of the setup but I guess that it would matter seeing that one engine will wind up quicker than another depending on the power.
Oh well, maybe I'll just sell it as a completely rebuilt unit that may or may not need to be re-curved depending upon the application.
Thanks Chris!
Old 02-14-2009, 06:51 AM
redvetracr
redvetracr's Avatar
you have whats known as a service replacement distributor....in your case it`s a rebuilt, recurved service replacement....
To Delco Distributor identification
Quick Reply: Delco Distributor identification
