Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-21-2009, 09:24 PM   #1
Ronaldo
CF Senior Member
Default 1968 radio?
Can somebody help me identify if this is a 1968 radio?
Model number: 7302721
Other number: 7303275
Ronaldo is offline   Reply With Quote
Old 01-22-2009, 08:47 AM   #2
gbvette62
CF Senior Member
gbvette62's Avatar
I'm in Kissimmee for the NCRS show, so I don't have any of my parts books, etc.. at hand. I can tell you that the 68-76 radios are all basically the same. The 68-71 face should have numbers with a green tint, the 72-76 numbers are white. I can't tell from the photos which face is on that radio. 68-76 radios have a separate amp, which isn't pictured. The amps used in 68 are unique to 68, where as the 69-76 amps are all the same (though stereo and mono each use a different amp). I believe the plug for the amp is the same on all radios.
gbvette62 is offline   Reply With Quote
Old 01-22-2009, 09:10 AM   #3
Ronaldo
CF Senior Member
Quote:
Thanks for the information. Its because my 68 is missing the original radio but the seperat mono amp is still in the car. I bought the radio on the pictures which (according to the seller) came from a 1968 corvette but I have not been able to find a place to verify the numbers...
Old 01-22-2009, 11:17 AM   #4
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
You might try contacting GM-Delco (or it's new name equivalent) in Kokomo, Indiana. They can identify the specific year by the codes on the tag. They helped me years back.
What you have looks like '68, but the 68-76 units all resemble each other.
Easy Mike is offline   Reply With Quote
Old 01-22-2009, 01:32 PM   #5
GoGreen
Junior Member
GoGreen's Avatar
Default Radio expert recommendation
Ronaldo:
I bought a 71 with an orig Delco radio & components in a box in unknown condition.
I sent them all to Jerry Rudbeck in South Carolina.
He did a great job of bringing the whole system back and explained exactly how it all went together. Also added an iPod input into the back of my U79 stereo that sounds great.
I recommend you email these pics to Jerry. He'll definitely help you out.
His email is: jerry@electrodesign.us
Good Luck, Tom
GoGreen is offline   Reply With Quote
Old 03-09-2009, 10:38 AM   #6
AvRog
CF Senior Member
That is the U69 option that I too have in my 69 and the numbers are correct. Let me know if you have any wiring info as all my connections have been cut.
Good luck, Roger.
AvRog is offline   Reply With Quote
Old 03-09-2009, 11:12 AM   #7
Ronaldo
CF Senior Member
Quote:
Good luck, Roger.
Thanks, can't help you with the wiring as all of mine also was cut. Damn you Bubba
Old 03-11-2009, 11:13 PM   #8
Jerry - Radio Guy
CF Member
Jerry - Radio Guy's Avatar
Ronaldo and AvRog, the 7302721 model number comes up as a 68 and was also listed as the chassis type for the 69 and 71 (that's from the Sams Photofact manuals and is supported by the little digging I did into the original Delco radio service manuals). Did you get the 7303275 number off the chrome escutcheon on the radios front? Too tired tonight to dig through all those parts manuals but it does not come up as a radio model type number. Wiring: there should be three plugs to work with. The one on the case side is -from front to back- radio power, ground and dimmer control. The connector with 3 pins -wires are usually colored blue, yellow, green- goes to the convector (the firewall mounted heatsink and big round transistor). If that's been cut you'd have to know more about radios to re-wire it. Plus, that pigtail is wired into the radio and is a devil to find aftermarket. (Supposedly I have two new ones coming in a shipment - I hope.) The third plug will usually have two green and one black wire (there were variations). The greens go to left and right speakers and the black is the common return (ground) from the second speaker connection on the left and right speakers. Hope that helps a bit... the 68-72's are a confusing mess as far as the numbers but usually consistent as far as circuitry. :-) Jerry www.electrodesign.us
Jerry - Radio Guy is offline   Reply With Quote
Old 03-12-2009, 07:57 AM   #9
AvRog
CF Senior Member
Thanks Jerry, what can I expect to pay for the convector?
Roger.
Old 03-12-2009, 08:27 AM   #10
Jerry - Radio Guy
CF Member
Well Roger, one went for $107 + shipping this week on eBay. Now, what should you expect to pay? Somewhere between $25-$40 US plus shipping WITH the connector and wiring attached. Don't plan on finding the harness easily in the aftermarket if it's missing from the heatsink. The entire unit comes up regularly on eBay - there are plenty of them out there.
Old 03-12-2009, 04:27 PM   #11
Ronaldo
CF Senior Member
Quote:
Originally Posted by Jerry - Radio Guy View Post
Ronaldo and AvRog, the 7302721 model number comes up as a 68 and was also listed as the chassis type for the 69 and 71...
Thanks Jerry. Yes the 7303275 number is from the chrome front.
Old 03-13-2009, 10:36 AM   #12
AvRog
CF Senior Member
Thanks Jerry
Roger.
Old 12-26-2009, 10:34 PM   #13
bkvette3
CF Senior Member
bkvette3's Avatar
Excellent Delco radio info on www.wonderbarman.com Should be able to find your answer there. Click on Delco models and date codes.
bkvette3 is offline   Reply With Quote
Reload this Page 1968 radio?
Tags
1968, 71, 7276, 7302721, corvette, delco, harness, jerry, model, no, product, radio, radios, rudbeck, stereo, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Advice-1972 Vette I bought on ebay Payshnt C3 General 54 06-10-2005 07:02 AM
1968 L89 59intheworks C3s for Sale/Wanted 18 06-19-2004 04:33 PM
1968 ONLY parts for sale C3 Parts for Sale/Wanted 22 04-16-2004 08:46 AM
If You Could Order A 1968-1982 Corvette What Would You Get? Corvette ED C3 Tech/Performance 40 12-11-2003 06:14 PM
ZL-1 heater/defroster/radio update DJ Dep C3 Tech/Performance 40 11-05-2003 07:49 PM
1968 LeMans Blue 427 Convertible for sale verskel C3s for Sale/Wanted 17 08-04-2003 06:11 PM
Post your '69 Pics WEB_War84 C3 Tech/Performance 36 01-14-2003 03:22 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
