Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-07-2009, 03:16 PM   #1
Ronaldo
CF Senior Member
Default 1968 radiator?
Hi
Can I identify if the radiator in my 68 (smallblock, A/C, auto) is the original?
Ronaldo is offline   Reply With Quote
Old 01-07-2009, 05:21 PM   #2
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
Sure does look like mine and mine is original. A big 4 row Harrison would be correct for AC and AT cars.
Easy Mike is offline   Reply With Quote
Old 01-08-2009, 07:32 AM   #3
Ronaldo
CF Senior Member
Quote:
Thanks, I getting it recored then.
Old 01-18-2009, 09:10 PM   #4
vetsvette2002
CF Senior Member
Aren't they supposed to be Aluminum ?
vetsvette2002 is offline   Reply With Quote
Old 01-19-2009, 01:06 AM   #5
gbvette62
CF Senior Member
gbvette62's Avatar
68-72 non-air, 4 speed (and 3 speed), small block radiators are aluminum. Air cars and big blocks have copper radiators.
gbvette62 is offline   Reply With Quote
Old 01-20-2009, 11:35 AM   #6
Easy Mike
CF Senior Member
Easy Mike's Avatar
Quote:
AC, big blocks, and smallblocks with AT got the big Harrisons.
Old 01-21-2009, 12:05 AM   #7
gbvette62
CF Senior Member
gbvette62's Avatar
That's why I said "68-72 non-air, 4 speed (and 3 speed), small block radiators are aluminum", but I guess I should have started my post with ONLY 68-72 non-air,.......... Oh well.
Old 01-21-2009, 12:39 PM   #8
Easy Mike
CF Senior Member
Easy Mike's Avatar
We're on the same page. I understood "three speed" to mean the base standard tranny, but the TH400 is also a three speed when you get right down to it.
Old 01-25-2009, 11:52 PM   #9
bigredbrad
CF Senior Member
bigredbrad's Avatar
Location: Lincoln NE Riding and Driving Corvettes since 1967.
Looks good by the tanks. Most dont realize the steel side brackets are distinct and these also look correct. Do not believe that the tag 16972? is original though and may have been added ad some time by a radiator shop as a way to tag it to correspond with an invoice number. Are you getting a dewitts core? If not, you will not have the same side brackets. All the cores that I have available to me other than dewitts have a completely different inverted type sidebracket. You may have that checked before your radiator shop orders a core from northern or another of the aftermarket core manufacturers
bigredbrad
bigredbrad is offline   Reply With Quote
Old 01-27-2009, 02:11 PM   #10
Ronaldo
CF Senior Member
Quote:
I was wondering what that number was...
bigredbrad
Thanks for the information, I did not know that. Unfortunately, I did not ask the shop what core they would use and its probably too late now. We have a local OEM radiator manufacturer (produces 10000 different radiator models) here in town, so I just thought they would get the core from there. Btw I live in Denmark (northern Europe).
Old 01-27-2009, 09:38 PM   #11
bigredbrad
CF Senior Member
bigredbrad's Avatar
If it was me, I would just have them remove that tag while they have the tanks off. I would ask them to sandblast the tanks to remove all the old paint and corosion prior to re-assembling everything. While the tanks are off, it is your only chance to hammer out all the dents and make the rounded corners all nice and pretty again. EVERY one we have ever had in our shop has lots of dents and gouges and it is much easier to hammer those dents out from the inside while they are off the core.
Regarding sidebrackets, the ones in your first picture look very original to me. The original Harrison cores had the steel sidebracket with a small square and small rectangle hold punched in each of the end. If the core is already ordered and the side brackets are different, and you are going for 100% originality, ask the shop if they can switch your old ones off and put them on the new one. This is definitely NOT a job for a rookie radiatorman, but if they have an old guy there, I bet he can do it.
Post some pics when done!
bigredbrad
p.s. to see a link to our website click here:
http://www.deansradiator.com/RadiatorRestoration.html
If you click on the first picture of the 427 radiator, you can see the incorrect, but current style inverted side brackets. Click on the picture to see it at full size and you can see the side bracket is shaped like a "U". This is technically incorrect, but this particular customer wanted the proper cooling of a new copper radiator without spending the extra money to put on the correct original harrison sidebrackets on. As you scroll down that page, you will see a sandblasted tank. Once all the dents are out, this tank will hold paint real nice and look great since all the old crud is sandblasted off.
Goodluck!
brad
Old 01-27-2009, 09:58 PM   #12
Tom DeWitt
Premium Supporting Vendor
Tom DeWitt's Avatar
Here it is
http://www.dewitts.com/pages/product...asp?ProdID=261
Tom DeWitt is offline   Reply With Quote
Old 01-27-2009, 10:19 PM   #13
bigredbrad
CF Senior Member
bigredbrad's Avatar
Thanks for posting that picture Tom. That is the same one that I bought from you to put in my 68 big block. Cools like a champ!
bigredbrad
Reload this Page 1968 radiator?
Tags
1968, 68, aluminum, big, block, cf, core, corvette, deansradiatorcom, harrison, radiator, remove, sale, small, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1968 conv. projectfor sale (poss. big block) scott's72 C3s for Sale/Wanted 18 01-25-2006 08:50 AM
1968 ONLY parts for sale C3 Parts for Sale/Wanted 22 04-16-2004 08:46 AM
Another Ebay what am I missing? $500 radiator cap!!?? LemansBlue68 C3 Tech/Performance 34 03-12-2004 08:00 PM
1968 LeMans Blue 427 Convertible for sale verskel C3s for Sale/Wanted 17 08-04-2003 06:11 PM
Aluminum radiator group purchase anyone? Michael Tucker C3 Tech/Performance 71 02-06-2003 01:13 PM
FS: 1968 Coupe, L79 with 42K original miles BillsVette C3s for Sale/Wanted 20 01-14-2003 07:56 PM
Post your '69 Pics WEB_War84 C3 Tech/Performance 36 01-14-2003 03:22 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
