Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-27-2008, 06:12 AM   #1
DAN70
Junior Member
Default Tcs
Could someone post a pic of a correct TCS set up for a '70 350/350 W/AC. Part #'s would be nice also. I did a seach but found no pics. Thanks...........
DAN70 is offline   Reply With Quote
Old 12-27-2008, 12:55 PM   #2
JohnZ
CF Senior Member
Support Corvetteforum!
Do you have the Assembly Manual? It shows all the wiring and vacuum components in the TCS system.
JohnZ is offline   Reply With Quote
Old 12-28-2008, 12:02 AM   #3
DAN70
Junior Member
Quote:
Sure do John, but sometimes a good color photo just helps to verify everything.
Old 02-01-2009, 03:40 PM   #4
dennis
CF Senior Member
dennis's Avatar
Quote:
dennis is offline   Reply With Quote
Old 02-02-2009, 10:16 PM   #5
DAN70
Junior Member
Thanks Dennis, thats beautiful. That steel vacuum line is a hard piece to find. I'd like to make one, if it's not to much to ask, could you give me the measurements of those bends?
Old 02-05-2009, 08:37 PM   #6
dennis
CF Senior Member
dennis's Avatar
I spent a couple of years researching that advance tube. It is nearly correct. The bends are right and I am in the process of finding a supplier for the double flare tube. You can get the piece right from classic tube in steel or stainless but single flare only. Tom there helped me out duplicating the piece from a known original I sent. Can't tell once the rubber hose is attached. Here's the info from classic tube
DENNIS
YOUR FRIENDS CAN ORDER THE VACUUM LINE FROM US @ $20.00 IN STAINLESS OR $15.00 IN OE STEEL USE PART NUMBER CVO1004-SS FOR STAINLESS OR CVO1004-OE FOR STEEL
TOM
Reload this Page Tcs
Tags
corvette, tcs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Onslought of ABS/TCS problems here SDVette C5 Tech 17 09-08-2005 10:34 PM
TCS problem with new rims and tires Ram Air Formula C5 Tech 26 01-22-2005 07:31 PM
Close call, you may not want to ignore TCS messages andy60 C5 General 10 01-03-2005 07:30 PM
Service ABS, Active Handling, TCS (have code), Code TCS C1214 - Problem is intermittent RskyBns C5 Tech 32 11-06-2003 09:13 AM
FS: CONSOLE PIECES, KNEE PAD, TCS SWITCH PANEL, AND DOOR PULL SURROUNDS batsallover C5 Parts for Sale/Wanted 10 04-20-2003 09:18 AM
Tuners Need Help: Just added Bauer Ported TB, now getting PCM & TCS codes. NVR BRNG C5 Scan & Tune 24 01-29-2003 07:57 AM
Something I didn't know - TCS is ALWAYS ON, sort of... Tom Steele C5 Z06 Discussion 12 11-01-2002 05:27 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
