Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-19-2008, 05:41 PM   #1
ukengr93
Junior Member
ukengr93's Avatar
Default CE block w/ cast date near Assy date
I am working on pulling together parts to build as close to factory correct engine for my 1969 L71 roadster which currently has a 454 in it.
I have found a CE 512 4 bolt block with an L 30 8 cast date. My car build date is January 7th, 1969. I already have some L3 and L4 8 (840) heads.
I would like some feedback/advice on this possible move as it relates to the ncrs world.
ukengr93 is offline   Reply With Quote
Old 12-19-2008, 10:17 PM   #2
Greg G
CF Senior Member
Greg G's Avatar
You will pick up 175 points for the corect casting date and 87 points for the correct casting date. Not sure if you will get points for the stamp pad finish which is worth 38 points. I think you will fget 50 points deducted for VIN and Assembly stamp.
As I understand the judging score sheets.
Greg G is offline   Reply With Quote
Old 12-20-2008, 09:02 AM   #3
ukengr93
Junior Member
ukengr93's Avatar
Is only one week prior to Assembly date for a block casting still considered acceptable w/ no deductions?
Old 12-20-2008, 04:29 PM   #4
JohnZ
CF Senior Member
Support Corvetteforum!
Quote:
That's a pretty close call - there were only five working days between the date the block was cast and the day the car was built, to get the block from the foundry to the engine plant, get it machined and assembled, then rail-shipped from Tonawanda to St. Louis, unloaded, and to the line.
I'd check with the '71 National Team Leader first (Stan Falenski) - his contact info is on the inside cover of the NCRS "Restorer" magazine.
JohnZ is offline   Reply With Quote
Old 12-22-2008, 12:30 AM   #5
joewill
CF Senior Member
joewill's Avatar
don't forget new years day I am sure was a GM Holiday.... so 4 working days..
I think the freshly cast block has to cool for 2 days.. prior to machining
joewill is offline   Reply With Quote
Old 12-22-2008, 10:09 AM   #6
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
Quote:
Originally Posted by JohnZ View Post
...That's a pretty close call...
I agree. Too close for comfort.
Easy Mike is offline   Reply With Quote
Old 12-22-2008, 06:01 PM   #7
ukengr93
Junior Member
ukengr93's Avatar
I went right to the source, Chuck Berge 68-69 NCRS team leader. He said it will not be a problem. Which just made my day.
Thanks to all those who weighed in. Learned a lot in the process. Steve.
Old 12-23-2008, 10:14 AM   #8
Easy Mike
CF Senior Member
Easy Mike's Avatar
...I went right to the source, Chuck Berge 68-69 NCRS team leader. He said it will not be a problem. Which just made my day....
Old 12-31-2008, 12:44 PM   #9
joewill
CF Senior Member
joewill's Avatar
it may not be a problem for the ncrs because it meets their criteria, but if I was a buyer I would pass on the car.. same is true the other direction, the ncrs says a 6 month old block can be put in a car and still pass... I would not buy a car with a claimed original engine, and pay original engine money, that was cast 6 months prior to the car build date.
Old 01-07-2009, 05:41 PM   #10
Vettebuyer5869
CF Senior Member
Vettebuyer5869's Avatar
Quote:
Vettebuyer5869 is offline   Reply With Quote
Reload this Page CE block w/ cast date near Assy date
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
