Do "matching numbers" still exist? Are they still relevant?
First time in this section, so excuse my ignorance...
View a lot of the SPEED TV "Dream car garage" etc. They are always talking about "matching numbers". I know it refers to the engine, chassis etc, and that it makes the car more valuable etc.
My question is, on a 2002 Z06, is all this still relevant?
I keep my car stock, but I'm curious if someone changed their engine, transmission, rearend, etc... on a modern car would this "matching numbers" thing come to haunt them if they kept the car 30 years and then went to sell it at Barret Jackson etc?
Matching numbers (engine, etc.) will be at least somewhat relevant for C5s at some point - the only question is when.
I do not believe that they will have as much influence on value as they do for C1s through C3s - I think one of the biggest reasons is the restricted engine variety in modern Corvettes. For example, your 2002 Z06 was only available with one engine, unlike the vast variety of engines available in earlier Corvettes (six in 1967, for example).
Hope this helps!
__________________ Lauren, 1985 Light Blue Metallic Coupe
Z51, Bose, leather, under continuing restoration
Mods: Dave McClellan's signature, "VERY 80S" plate
Grace, 2003 50th Anniversary Convertible - Museum Delivery during 2003 C5 Birthday Bash
Mods: Dave Hill's signature, Blackwing, AutoBuffs fuel rail covers, "50 GRACE" plate, etc.
Louis, 2012 Centennial Edition Coupe - Museum Delivery
Mods: "LUFF" plate
IMO, anything after about 73 or 74 numbers matching by itself doesn't mean much. Like said above, there weren't a plethora of engine options and starting in 72, the VIN told what engine came in the car. An original low mileage car will always be worth more and be "numbers matching". If you are talking about a higher mileage driver I don't think it does. No one asks me if my 92 LT-1 is original or numbers matching, but I get that question all the time with 70 LT-1.
Well, that's seven engines, six options. Now add in the M20, M21, M22 4spd and Powerglide automatic and then add in the rear axle ratios of 3:08, 3:36, 3:55, 3:70, 4:11, 4:56 and now you would have different drivetrain combos.
Don't be missled by the term matching numbers. Original and matching numbers are not the same thing.On older cars you want to look for one that is original. Then the trans and rear end and engine will be stamped with the serial #. Viet
