Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-11-2007, 09:36 PM   #1
RPOL36
CF Senior Member
Default ? for a NCRS guide that knows 68's fairly well
see this post please
http://forums.corvetteforum.com/show....php?t=1733240
RPOL36 is offline   Reply With Quote
Old 08-20-2007, 11:45 PM   #2
Procrastination Racing
CF Senior Member
Procrastination Racing's Avatar
I can't be 100% since I didn't buy the car new, and I have had the engine out a couple of times, but pretty sure I have the original bolts back in.
Anyway, mine matches the top rusty one. The bolt "head" is too thin I think to properly space the bracket. You would need a thick washer in there.
Procrastination Racing is offline   Reply With Quote
Old 08-22-2007, 07:25 PM   #3
RPOL36
CF Senior Member
thanks I personally thought the bolt I removed was probably the correct ony myself because this car is pretty much in tact down to correct bolts etc..
Not sure what you mean by "The bolt "head" is too thin I think to properly space the bracket. You would need a thick washer in there.
" which bolt the new incorrect one or the old original?
can you explain that a little more I'm kinda lost. but all in all the new one I recevied from paragon doesn't match whats your on 68 bb but the rusty bolt I removed does?
thanks again!
Old 08-23-2007, 12:45 AM   #4
CF Senior Member
I said "head" because I guess this stud doesn't really have a head. If it were a bolt, and the part you put the wrench on, that would be the head. The same on this one but it has a second threaded stud sticking out of it.
Notice the rusty one you have is thicker (taller). The new one is thinner (shorter). Since they didn't use washers on the '68 exhaust bolts, then a washer would be instantly noticed as incorrect. but it would be necessary to put on the stud to space the PS bracket out to the right spot. It is only an 1/8th inch probably, so the bracket no doubt has enough flex, but then it would be in a bind and could fracture years from now.
Old 08-23-2007, 06:12 PM   #5
RPOL36
CF Senior Member
ok which also says that the old rusty one is correct and I will be sure I re-use it instead of the new incorrect one.
thanks
Reload this Page ? for a NCRS guide that knows 68's fairly well
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
