Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-13-2007, 12:25 AM   #1
teamlorenz
Junior Member
Default 69 Number questions
Ok
I have a 69 Coupe. It has a 78 small block in it now.
The rear end has big block caps on on side and small block on the other. the rear end must of been replaced since the one in there now says OK 314 W7E 1 so it is out of a 77 vette. it has the rear sway bar. transmission is stamped P8E08E 18NZ436067, the last numbers don't match my vin.
the tach is 5600 RPM.
on the underside of the rear compartment is 465 AC does anyone know what that means?
I am just trying to maybe find out what engine it came with.
teamlorenz is offline   Reply With Quote
Old 07-13-2007, 10:21 AM   #2
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
465 is almost certainly the job number assigned in the body shop at St. Louis. Add 500 to it and see if 965 are the last three digits of the VIN. 465 or 65 might also be on the passenger's side of the tranny tunnel and down low on the right corner of the firewall under the hood.
AC is also an assembly line mark indicating the car was to have factory air.
Without further documentation, determining the original engine might be a problem. At the least, if the car was to have factory air, you know the original engine was not any combination which excluded air (L-88). Does the car have a factory rear sway bar? If so, she was an original big block. Can you see any evidence of the tank sticker?
Easy Mike is offline   Reply With Quote
Old 07-13-2007, 09:09 PM   #3
JohnZ
CF Senior Member
Support Corvetteforum!
Quote:
The P8E08 says the transmission was made on May 8, 1968, but it shouldn't have the last "E" character (which was either an A, B, or C - "E" wasn't used); the 6th character wasn't added until mid-October, 1968, during the 1969 model year.
The partial VIN shouldn't have the "Z" in it, and otherwise indicates that case was originally installed in a 1968 Camaro built at Norwood, Ohio.
JohnZ is offline   Reply With Quote
Old 07-15-2007, 10:08 AM   #4
gkvetteuno
CF Senior Member
My 69 427-400hp has the 5600 RPM tach. The 427-390hp also had the 5600 tach. They are the only 69 engines to use this red line. Also the radiator core on the 427 was 27 1/2" wide. 350 was about 26. Core support will also reflect this. Holley equipped 69's did not have a fuel return line(400hp w/3x2), the Quadra-jet cars did(390hp). Also AC could not be had on the solid lifter 427's(435hp, L88). The factory rear axle for 427 and 4-speed w/ac would be a heavy duty 3:08 with AW code.
AG
gkvetteuno is offline   Reply With Quote
Old 07-16-2007, 02:55 PM   #5
teamlorenz
Junior Member
Default 69
the radiator is 27.5 inches. I will check on the return fuel line. I do plan to drop the tank but i am almost sure nothing is there.
I guess without the tank sticker it really doesn't matter what engine it came with.
Old 07-16-2007, 05:29 PM   #6
gkvetteuno
CF Senior Member
The tank sticker is definitely a nice piece of documentation to have but it is also important as to what engine the car was originally equipped. From all indications your car appears to be a 427 coupe with factory AC and 4 speed, a desirable combination and worth significantly more than a small block coupe. This alone would be a big factor for me in determining what to do with the car as far as restoration. Find a 427 block with the right casting #'s and dates 1 week to 6 months before your car build date and you are on your way.
AG
Old 07-16-2007, 07:32 PM   #7
teamlorenz
Junior Member
Default 69
It does look like it has a return fuel line, 1 line goes to the bottom of the tank and the other goes up high and out of my view
Old 07-17-2007, 01:46 PM   #8
teamlorenz
Junior Member
Default 69 f41
the rear leaf spring is a 7 leaf could you get the f-41 suspension with a small block?
Old 07-18-2007, 10:10 AM   #9
gkvetteuno
CF Senior Member
Here is a link I ran across on another site http://www.ncrs.org/forum/archive3.cgi?review=13970
This site is useful to research other aspects of your car. Their archives have a ton of information.
AG
Old 07-18-2007, 03:07 PM   #10
JohnZ
CF Senior Member
Nope. Most likely a replacement.
Reload this Page 69 Number questions
Tags
69, corvette, numbers, p8e08, questions, transmission, vin
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
69 Corvette 427 question dhauser C3 Tech/Performance 17 06-28-2004 07:01 PM
Converting my tube frame drag race '69 back to a street car. Question... 632C2 C3 Tech/Performance 36 05-07-2004 03:28 PM
Hi Everyone I am a new Owner of a 69 Just checking in Faster & Faster C3 Tech/Performance 36 12-29-2003 11:11 AM
Ignorant C5 owner with a few C3 questions... Sparticus C3 Tech/Performance 23 03-03-2003 04:53 AM
Who here know's 1969's like the back of thier hand?? I have questions.... phrogs Factory Correct Resto 27 12-13-2002 10:13 PM
350 rebuild questions Burgundy 69 C3 Tech/Performance 9 12-02-2002 12:31 PM
Couple 69 Vette Questions... Valleybacker C3 Tech/Performance 11 03-09-2002 07:05 PM
'69 Underhood photos needed ddecart C3 Tech/Performance 25 08-09-2001 01:05 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
