Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-16-2007, 09:31 AM   #1
mstanton
CF Senior Member
mstanton's Avatar
Default LT-1 Radiator
Is there anywhere to purchase a reproduction radiator for a 70 LT-1? What other corvettes used the same radiator as an LT-1?
mstanton is offline   Reply With Quote
Old 06-16-2007, 02:29 PM   #2
Bullshark
CF Senior Member
CI 5 & 8 Veteran
Bullshark's Avatar
Mark, can you take it and get it re-cored. That way with the original end tanks, it is still original......at least by my definition
Bullshark
Bullshark is offline   Reply With Quote
Old 06-16-2007, 05:35 PM   #3
mstanton
CF Senior Member
mstanton's Avatar
It's not the core that's bad. I damaged the end where the drain screws in when I was putting the car back together after I rebuilt the front end. I've found a machine shop that thinks they can fix it. Just looking for a back up in case they can't.
Old 06-17-2007, 09:18 PM   #4
a560156
CF Senior Member
Quote:
If you are looking for the Harrison Tanks, no one is making them. And good luck finding a good used one. I had the same problem and my radiator shop soldered in a piece for me - works fine.
a560156 is offline   Reply With Quote
Old 06-18-2007, 10:53 AM   #5
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
...I've found a machine shop that thinks they can fix it...
That's the way to go if your LT-1 is otherwise original.
Easy Mike is offline   Reply With Quote
Old 06-18-2007, 11:22 PM   #6
GaryS
CF Senior Member
GaryS's Avatar
I would give the folks at DeWitts a call and see if they can give you some advice.
Gary
GaryS is offline   Reply With Quote
Old 06-19-2007, 12:27 AM   #7
Tom DeWitt
Premium Supporting Vendor
Tom DeWitt's Avatar
Quote:
Gary
If the end tank is toast, then this one will work. It doesn't have a hole in the bottom for a drain, but you can add it.
http://www.dewitts.com/pages/product...asp?ProdID=295
If it's just a striped out bushing, any radiator shop will stock those. It's a standard solder in bushing.
Tom DeWitt is offline   Reply With Quote
Reload this Page LT-1 Radiator
Tags
engine, lt, radiator
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
For Sale - 1970 LT-1 Convertible Midyrman C3s for Sale/Wanted 18 06-14-2003 03:56 AM
LT-1?????????? drpepperkid C4 Tech/Performance 26 05-01-2003 01:59 PM
1970 LT-1 Convertible for sale Midyrman C3s for Sale/Wanted 13 12-21-2002 10:09 AM
oil cooler for an LT-1 CallawayC12 C4 Tech/Performance 17 11-03-2002 04:01 AM
1970 LT-1 Robert N C3 Tech/Performance 22 04-22-2002 12:18 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
