Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Factory Correct Resto
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-18-2007, 10:24 AM   #1
clthom2
Junior Member
Default 90 Vette popup lights problem
I have a 90 Vette with 51K miles and always garage kept. My car was disabled for about 10 months. I got it fixed. When I turn on the lights they popup a little slow and sometimes get stuck before opening to the correct position. Nothing is obstructing the lights. Before the car was down I never had any problems with them. What can I do.
clthom2 is offline   Reply With Quote
Old 05-18-2007, 02:40 PM   #2
Easy Mike
CF Senior Member
Cruise-In II Veteran
Easy Mike's Avatar
Battery in good shape? Otherwise, sounds like the gears in the motors. The factory originals are plastic and can deteriorate with age. The aftermarket providers offer bronze replacements.
Easy Mike is offline   Reply With Quote
Old 06-29-2007, 02:20 PM   #3
phrogs
CF Senior Member
phrogs's Avatar
its not the gears that go bad it is the bushings that are inbetween the gear and the shaft that runs out to the links that position the light up or down.
Click on the link you need the bushings not the gear the gear is a waste of cash unless yours are toast, pull the motors and check them out it might seem a bit intimidating on the first light bt once ou get it back together then youll go fast on the other light.
enjoy
http://www.madvet.com/shop?frame=3.249.853
phrogs is offline   Reply With Quote
Reload this Page 90 Vette popup lights problem
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
? about buying a C5 gmintimidator C5 General 10 03-21-2005 02:37 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
